suspension change ?
Old Jun 23, 2001 | 01:00 AM
gunslinger150's Avatar
gunslinger150
suspension change ?
I just purchased a 1964 ford custom cab,I would like to switch out the old springs and i beam for the newer twin i beam and disc brake for the front end is this possible?I have a 1982 crew cab that i can use for parts.I really dont want to put a mustang 2 cross member in this as i would like to keep the 390 eng. in it.Thanks for the help! i appreciate it.
Old Jun 23, 2001 | 06:21 AM
jowilker's Avatar
jowilker
suspension change ?
Jeff, Anything is possiable with enough engineering. I have never heard of anyone here making claim to your project, but was talking to someone in Carlisle last weekend who said it would work. Measure everything 10 times and everyway from sunday before you start. Keep good records and you may be able to help others if you can pull it off.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Jun 23, 2001 | 04:08 PM
gunslinger150
suspension change ?
Thanks i will keep checking i will check measurements and see what i come up with.Also need to find new windshield and rubber to put back into truck any info would be appreciated.
Old Jun 23, 2001 | 10:01 PM
jowilker's Avatar
jowilker
suspension change ?
Rick at Carolina Classics 800-598-4211 has the rubber and your favorite glass co can get the new glass.
John
jowilker
66F100s Rule
Old Jun 25, 2001 | 11:21 AM
jowilker's Avatar
jowilker
suspension change ?
Old Jun 27, 2001 | 07:54 PM
BitLittl's Avatar
BitLittl
suspension change ?
If you will use a73 to77 FORD truck frame you can set your motor and tranny in it as the motor mounts do not have to be made.However you do need to bring the steering column up so that it will come out of the fire wall at the proper place.Also you will need to bring front cab mounts back about 4 inches to line up with the 64 body mounts.The73 to 77 frame is a rear steer frame and makes a good donor.The 78 and 79 frame is several inches wider and is not a good donor. Hope this will help you.
88_F0RD
Dec 30, 2016 12:37 PM
Rick Schmidt
Mar 30, 2014 01:23 PM
oldford65
Sep 12, 2013 06:40 PM
mr.mischief
15
Jan 31, 2011 07:28 AM
JockD
Apr 7, 2009 09:59 AM
