83 Frame and I beam Question
Old Mar 27, 2014 | 09:26 PM
Rick Schmidt's Avatar
Rick Schmidt
Doing some work on my 83 to replace a spindle Thought maybe it'd be easier to get the spindle and the I beam as a unit Yard the spindle is coming from realized there are two different I beams in the trucks...Truck is a 2wd originally an inline 6 One is like a welded box ? other is the Cast I beam. When they realized this they asked if we were sure the pickup was a 150 and not a 100. Did 100s and 150s have different I beams ?? Mines an 83 bt maybe the cab ended up on an older frame. Are the vin numbers on the frames too ? Where else can I look to match up the vins ??
Old Mar 27, 2014 | 09:36 PM
MeanGreen460's Avatar
MeanGreen460
What is your Truck F150 or F250 .I believe the F150 had the boxed twin I beams and the F250 the solid cast beams
Old Mar 27, 2014 | 09:49 PM
ctubutis's Avatar
ctubutis
Last year for the F100 was 1982.
Old Mar 27, 2014 | 09:50 PM
Gary Lewis's Avatar
Gary Lewis
Actually, plenty of the 150's have cast. Ray1986F150's are cast, for instance, and it is a light duty 150 with a 302.
Old Mar 27, 2014 | 10:20 PM
MeanGreen460
I was probably thinking a F100 .I know a lot of F150s were cast .
Old Mar 27, 2014 | 10:36 PM
Rick Schmidt
Truck is a 150.. 5 lug wheels an all but today I seen 3 different Bullnoses and only 1 had the Boxed ones like mine think it was the 82 in the yard. I just dunno the difference. Are the boxed ones stronger ?? Lighter ... did the original motor define them ??
Old Mar 27, 2014 | 11:02 PM
MeanGreen460
Personally I think the cast ones were much better .The boxed ones were probably cheaper to make. As you all know the Auto companies are always wanting to make stuff cheaper using less or cheaper material. they never know how to leave a good thing alone that works and lasts.
Old Mar 28, 2014 | 07:30 AM
Gary Lewis's Avatar
Gary Lewis
I would prefer the cast as well. But the only real reason I have is that it is easier to press, push the bushings out as the boxed ones will collapse if not done correctly.
Old Mar 29, 2014 | 11:52 PM
Rick Schmidt
Do the Cast ones swap in directly ?
Old Mar 30, 2014 | 05:39 AM
Ranger80's Avatar
Ranger80
1983, we had one about 10 years ago.
Old Mar 30, 2014 | 07:52 AM
Gary Lewis's Avatar
Gary Lewis
Yes. They are a direct swap.
Old Mar 30, 2014 | 11:49 AM
ctubutis's Avatar
ctubutis
Yes, you are correct, the parts catalog verifies it.
Old Mar 30, 2014 | 01:23 PM
Gary Lewis's Avatar
Gary Lewis
fiftysixfordf250
31
Jun 14, 2013 07:23 AM
WarriorWithin
Jun 25, 2011 12:33 AM
pintoches
Feb 10, 2007 11:01 AM
Dustin_86
50
Nov 23, 2006 09:16 AM
GeneStoner
20
Jan 11, 2003 08:15 AM
