2001 Ranger 4x4 control module
Old Sep 14, 2006 | 03:42 PM
enpop1's Avatar
enpop1
Hi... hoping someone can help. I have a 2001 ranger xlt 4x4 that, when turning the 4x4 switch on the dash, will not engage. I had it to the local Ford dealer today, and they said that the 4x4 control module is bad and needs replaced. First... is there anything that can be done to check to see if this really is the problem (also where it's at, etc,) and second... can these modules be purchased ad installed without having to give 500 bucks to Ford?
I'm a first time poster and don't really know too much about trucks, so please go easy.
Thanks for the help.
Old Sep 14, 2006 | 07:11 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
To replace the 4WD control module:
1. Remove the passenger cowl side trim panel.
2. Disengage the locking tangs and remove the harness connectors.
3. Remove the screws.
4. Remove the 4WD control module.
To install, reverse the removal procedure.
The "passenger cowl side trim panel" might be better described as the side trim piece down by the passenger's foot well.
Old Sep 14, 2006 | 07:12 PM
rubydist's Avatar
rubydist
The 'switch' activated 4wd has an actuator that sits on the side of the transfer case that is actuated by the switch position on the dash. Presumably, the dealer verified that the electrical signal is getting to the actuator and that nothing happened - otherwise you should verify that the signal actually arrives at the actuator. If you verify that this is the situation, you can purchase and install the actuator yourself, if you are so included. I'd suggest you first buy a Chilton's or Haynes service manual for your truck as it can help you with things like this - they are around $20 and at many bookstores.
Tkrobinson
Dec 7, 2018 08:22 PM
brc777
Jan 11, 2017 05:46 AM
roghoge
Jul 23, 2015 06:09 PM
jlb911c
1978 - 1996 Big Bronco
Feb 23, 2015 08:14 AM
SPreston2001
Jun 28, 2008 06:51 PM
