I'm trying to "wake up" a 302 in an '83 F-100 without ruining my fuel economy. I need a little more low-end torque since I'm now running 265/70R16 tires with a 3.50 axle ratio and AOD transmission.
I am looking at the Competition Cams Xtreme Energy XE250H with a 206/212 duration at .050" and a .289"/.296" lift and 110 degree lobe separation.
I'm also looking at a Crane Cam 260 H10 Hydraulic Energizer with 204/204 duration at .050" and .285"/.285" lift.
Has anyone tried these cams and liked them? Will either work with stock valve springs and push rods? (I know I'll need new lifters with a new cam.) I'm in the Houston area and the truck will have to pass emissions tests. Will the addition of a cam hurt me there? Any and all comments are welcome.
The Energizer should be OK with stock springs. But if those springs have over a hundred thousand miles on em, you really need new ones.Your stock pushrods should be Ok as well, but give them a good visual inspection before reusing them. The ends mainly, they should have an even round profile. Change any that don't look right. New pushrods are cheap. The Extreme Energy cams don't work with stock springs or other components.
Is this a better cam for what I want? I haven't put a cam in anything since I put a Sig Erson cam in a '81 Bronco 351M back in 1988 or so. I remember I could still get about 15mpg on the highway if I was careful and didn't have any trouble revving to sling mud out of my 31-10.50's. What should I expect performance-wise from cams like these?
Agree with baddad- pushrods are cheap, I'd replace them. But, if you do decide to re-use them, be sure to put them back in the same holes they came out of. They wear to a specific rocker arm, just like flat tappet lifters to a cam. On the subject of cheap pushrods- if you go with the cam that requires a spring upgrade, don't scrimp on the pushrods. This may be one of the most overlooked part of the valvetrain. You want the stiffest rod you can afford. Either thicker walled, or tapered (fatter in the middle, which may require opening up the holes), to maintain optimum valvetrain geometry. With higher lifts and more open spring pressures, the pushrods can deflect (think polevault). When this happens, you're not going to realize the full benefit of your higher lift cam, and at higher rpm's contributes to valve float. Just my 2 cents.
I've never put pushrods back in order and never had any problems from it. Lifters? Yea, pushrods, no. Only pushrods I've seen wear funny are the ones in a roller motor, and that's due to the fact they don't spin like flat tappet rods.
