Hellwig
Old Mar 7, 2007 | 09:42 AM
jdadamsjr's Avatar
jdadamsjr
Have been in LOOOOOOOOOOOOOOOOOOOOOOOOONG discussion about difference between stock 24mm bar and 30 mm camper package bar and $179 Hellwig.... with free shipping today from JC whitney...
short story?
if ya got nuthin do the Hellwig - if ya got something and are happy - good for you !
but bottom line? the material and torsional rigidity of the hellwig are FAR better than the stock bars....
I think someone worked it out to like 30% better roll control IIRC...
(if everything on the stock trucks are the best, why do we need to upgrade anything ? )
Old Mar 7, 2007 | 11:12 AM
Cobra 427's Avatar
Cobra 427
Has anyone swapped out their stock front sway bar for the Hellwig front sway bar? And if so, was there a noticable difference?
Old Mar 7, 2007 | 12:27 PM
RACERX7775's Avatar
RACERX7775
i am not sure what the diameter is on the front hellwig bar but my stock front bar is metric and its 36mm. i got one of those sway bar measuring tapes that wraps aroud the bar. wow, thats big.
well, lets see how this works...i cant wait to see how different it rides and handles.
i ordered the hellwig rear sway bar, aset of 4 billstein shocks, and a dual inline front stabalizer shock setup yesterday. parts should be here in 5 days....
Old Mar 8, 2007 | 01:16 PM
expy98's Avatar
expy98
fwiw, did Bilsteins and rear Hellwig recently. The parts on the Hellwig had to be modified slightly to install (bend the U bolts and maybe slotted some holes). Also, the brackets for the brake lines/cables don't want to go back in place. Also got mine from JCW. Look up a member's writeup w/ lots of pics since the instruction leaflet is pretty spartan.
Old Mar 8, 2007 | 04:00 PM
RACERX7775's Avatar
RACERX7775
Who Is The Member That Has A Good Writeup With Pics? Thanks..
Old Mar 8, 2007 | 04:06 PM
expy98's Avatar
expy98
https://www.ford-trucks.com/user_gal...?albumid=13001
props to the author, Scott Wheeler.
Old Mar 8, 2007 | 04:09 PM
RACERX7775's Avatar
RACERX7775
Thanks, Thats Perfect. I Appreciate It.
Old Mar 9, 2007 | 05:25 PM
gabeyd's Avatar
gabeyd
I recently (a couple of months ago) put the rear Hellwig on my 2000 Excurstion. It fit fine, other than mounting the e-brake retaining clip on the driver's side, I had to fudge that a bit. It doesn't look quite the same as the one in the pictures linked a few posts up. The down links are quite a bit different. I can take some pictures of the fully installed one if anyone is interested. I bought it at JC Whitney as well.
It does make a nice difference in handling, but not a huge Wow. That's compared to no rear, and factory still up front.
houstontxex
Jul 16, 2012 06:25 PM
02puffer
Mar 15, 2009 09:14 PM
high1
Sep 26, 2007 02:59 PM
dddenio
Aug 4, 2004 08:19 AM
