strange noise while turning
Old Mar 7, 2007 | 02:38 PM
mike330's Avatar
mike330
I noticed a strange noise today while turning full lock left or right. It is similar to the noise you here when you are in four wheel drive and turn the wheel. It sounds like a shuddering noise. Could the 4 wheel drive not be disengaging all the way?
Old Mar 7, 2007 | 04:06 PM
boggerted's Avatar
boggerted
If you turn the wheel full right or left, the power steering makes a noise because it is trying to push it farther but cant. Its normal
Old Mar 7, 2007 | 04:25 PM
mike330's Avatar
mike330
Its makes the grinding while moving. It sounds like the four wheel drive is still engaged but not as extreme. I know the sound you are thinking of .
Old Mar 7, 2007 | 04:47 PM
areed's Avatar
areed
Could be your limited slip differential. We had an expedition that made noise when turning hard left or right, friction fluid helped to fix that.
Old Mar 7, 2007 | 05:59 PM
mike330's Avatar
mike330
So you think the noise is coming from the rear? It feels like its in the front , but I know what your talking about with posi binding.
Old Mar 7, 2007 | 06:30 PM
areed's Avatar
areed
On my expedition, I totally thought the was in the front-end. After digging further, it was in the rear-end and the fix was relatively easy.
Hopefully I'm not taking you out on some wild goose chase, just relating my situation.
Old Mar 7, 2007 | 10:58 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Had the exact thing just happen to me 2 weeks ago.its not the 4 weel drive it the beriens
Old Mar 8, 2007 | 04:48 AM
mike330's Avatar
mike330
Did yours do it only while fully turned. ? What was the fix? New bearings
Old Mar 8, 2007 | 07:29 AM
MarkMoore's Avatar
MarkMoore
Make sure your hubs are disengaged - reach under and try to turn each front axle, if you can't then they are engaged; if you can, then they are free and you need to look at other causes.
Old Mar 8, 2007 | 08:21 PM
mike330's Avatar
mike330
So I should be able to reach behind the wheel and turn the axle? How about the front drive shaft? Should that turn also?
Old Mar 9, 2007 | 05:57 PM
mike330's Avatar
mike330
Ok the axle does not turn when the hubs are unlocked. Does this mean new hubs?
Old Mar 9, 2007 | 06:36 PM
Monsta's Avatar
Monsta
Sit. Stay.
No, it means you can try to unstick them.
I've been able to move the selector (LOCK/AUTO) back and forth while movin gthe axle shaft back-n-forth and eventually get the hub to unlock. Start there and see what happens.
You can also switch it to 4HI and back to 2WD and see if the vacuum pulse will unlock it.
cwnitsuj
2004 - 2008 F150
Feb 12, 2013 08:13 PM
dehamma
Nov 7, 2011 12:44 PM
Mustang6t7
Oct 9, 2009 08:50 PM
berry1234
Apr 10, 2008 05:10 PM
jaxf250
Jan 5, 2003 09:34 AM
