Sponsored by: Real Truck
DRW Front Rotors
Old Sep 13, 2006 | 10:20 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
DRW Front Rotors
On a 2000 DRW 2WD do the front rotors separate from the hubs or do you have to replace the whole thing, also are there any slotted rotors available for the DRW.
Denny
Old Sep 14, 2006 | 06:43 AM
DetailerDave's Avatar
DetailerDave
The rotors should be the same for SRW and DRW. DRW has a bolted on spacer between the wheel and the rotor to make up for the different back spacing of the DRW wheels.
Old Sep 14, 2006 | 01:13 PM
harald's Avatar
harald
ART makes slotted, cryo treated front rotors for the dually. The extension piece just unbolts. I did my truck over 2 years ago with their rotors and pads and have had no problems since.
Old Sep 19, 2006 | 10:14 AM
rvpuller's Avatar
rvpuller
Well I found out yesterday that the front rotors for a DRW 4X4 are bolted to the spacer but the 2WD are not its all one all piece and its not cheap, Ford $246.00 each and aftermarket $189.00 each, and there are no slotted ones for the 2WD. I removed one of my wheels and the existing ones don't look that bad so its new pads, I have never had any luck with turning rotors and not have them warp right away and mine are not warped so I'm going to give it a try all I will be out is a set of pads.
Denny
