Sponsored by: Auxito
More problems
Old Sep 13, 2006 | 09:29 PM
kDemler's Avatar
kDemler
Red face Brake Woes
As if my window problem wasn't enough, last night my brake line finally gave out. After losing brakes, I inspected the lines only to find them severly rusted (one of which was completely through).
Now the question: From the master cylinder the brake line is coiled. Is this required (in other words do I have to go to the dealer to buy the new lines or can I get straight lines from an auto parts store and run them straight)?
Also, is there anything particular I need to do to bleed the system with regard to the anti-lock brakes?
Thanks in advance.
'98 F-150 Extended Cab; 4.6L; 2WD; 80K miles
Old Sep 14, 2006 | 09:35 PM
Racerguy's Avatar
Racerguy
Some brake lines are coiled so they can move a bit more than a straight one.
I'd buy the same length as the original and coil it yourself, around a can or something.
Bleeding the brakes on these is the same as a normal vehicle.
grip1968
May 23, 2012 06:22 PM
RedBandit
Apr 13, 2008 06:17 AM
G2IC_Wraith
1983 - 2012 Ranger & B-Series
15
Oct 3, 2006 04:47 PM
hogsbreath22
Offroad & 4x4
Sep 25, 2006 05:00 PM
dcdcccdc
13
Aug 8, 2006 10:52 PM
