Steering Wheel Vibration, Rocking Back and Forth
Old Sep 13, 2006 | 03:44 AM
orange_x_crush's Avatar
orange_x_crush
My 2000 Navi steering wheel started to rock back and forth when going down bumpy roads at 15-50 mph. On the highway its fine at speeds up to 80+. I jacked up the Navi and checked to see if the ball joints are bad. About 9 months ago I had the lower ball joints replaced, and the sway bar fixed. The only play I got was the Idle Arm Damper was in pretty bad shape. I replaced the Idle Arm Damper and it cleared up a mojority of the shaking. I have Continental tires which I've heard were junk. Is there a way to check the steering gear box? Tie rod ends seem to be fine. Also too, does anyone have an opinion on what tires. I like Michelins, but don't want to pay a bunch>
Thanks!!!
Old Sep 13, 2006 | 12:07 PM
projectSHO89's Avatar
projectSHO89
Sure. Just look for a differential in the input vs output motion.
If there is a noticible rotation of the steering wheel without a corresponding movement of the Pitman arm, then there is slop in the gear.
I have ALWAYS been happy with Michelin LTX tires even though I'm not currently running them.
Every stock Conti I've ever owned have been lousy, much like every stock Firestone I've ever owned has been.
Steve
Old Dec 18, 2006 | 09:25 PM
oskie's Avatar
oskie
I have a similar vibration or rocking in my steering (06 expy) when traveling at slow speeds on uneven or rough pavement. No problems at highway speeds. Crush, give us an update.
Old May 13, 2007 | 11:22 AM
orange_x_crush
I changed out the Pitman arm. Pretty bad. 80 bucks at the dealership. Cheaper off of eBay. That helped some. I have a few other things loose. Tie rods, and such. But my steeping wheel is way too easy to turn. Thats more of a problem. I'm not sure if its the steering assist.
