Chassis Trouble Code, can't find on articles/specs page, HELP!!!!!
Old 09-12-2006, 08:24 PM
mdjohnson's Avatar
mdjohnson
mdjohnson is offline
Question Chassis Trouble Code, can't find on articles/specs page, HELP!!!!!
I scanned me truck today and it came up with code C6200, I have a 2001 F-150 2WD with a 4.6L. It is a chassis code and most the sites I go to don't go above a C2000 code. Sometimes the airbag light blinks.
I also got code P1311, that is Lack of upstream heated oxygen sensor switch-sensor indicates lean-bank #1
Does that mean I have a missing cylinder on bank 1? Which side is that?
Thanks.
Old 09-12-2006, 09:53 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Bank 1 is the passenger side.
Sounds like the sonsor could be bad. Usually P0171 and P0174 are for lean conditions.
I can't help you on the C6200, sorry. You can try this link. http://www.obdii.com/codes_request.asp
Old 09-13-2006, 07:20 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
That's not a valid Ford chassis code. Most likely the result of using a tuner to pull the codes instead of a dedicated scan tool. If this is the case, contact the tech support people for your tuner module. In the meantime, I would ignore it as invalid and likely the result of a testing error.
The flashing airbag light is a two digit code. Count the flashes and see what the Lamp Fault Code (LFC) is.
P1311 is not a valid code. I assume you meant P1131 which usually points to a worn out/ lazy upstream sensor on the passenger side. This one is a fairly reliable indicator that the sensor is in need of replacement.
Steve
Deckmonkey
2004 - 2008 F150
12-10-2023 02:08 AM
hofec1
2004 - 2008 F150
37
11-26-2020 01:45 PM
nitrored
1997 - 2003 F150
10-03-2016 05:03 PM
VCB
Modular V10 (6.8l)
12-17-2013 05:47 AM
velcro7279
1997-2006 Expedition & Navigator
06-06-2011 06:51 AM
Quick Reply: Chassis Trouble Code, can't find on articles/specs page, HELP!!!!!
