Shock question
Old Sep 11, 2006 | 10:49 PM
t_lcohen's Avatar
t_lcohen
Shock question
Ok, help a dummy out here. I have two expy's. A 97 eddie and a 99 XLT model. I bought front and rear shocks for the 97 but was unable to remove the old shocks from the vehicle. It appeared that the actual lower mounting bolts were welded onto the frame work of the vehicle. I eventually gave up trying figuring I would just a shop to do the installation for me. Well life got in the way and it never got done. I was working on the 99 front brakes the other day and thought I would install these shocks on that vehicle instead since the bolts were not welded on per say. I was able to remove the old shocks, but then the problem came in. I was unable to compress the shocks enough and keep them compressed enough to get them mounted in the mounting holes. Is there something I was doing wrong or is there another tool I need for this task. Or is it just that the shocks are not interchangeable between the 99 and 97. The shocks are Gabriels and the rear ones came with a retaining wire wrapped around the shock keeping them compressed until they were installed then you simply cut the wire loose. Any help anyone can share would be great. Thanks, Tommy.
Old Sep 12, 2006 | 07:47 PM
thecardoc's Avatar
thecardoc
I assume both are 2wd , if they are the shocks are fully interchangable front and rear between both . As for the the compression of the shocks you just have to push them into place and then very quickly get the bolts in place while holding them there .
The bolts are welded to the lower control arms on the front (2wd) only but the nuts should come off with help of a good penatrating oil like pb blaster or deep creep .
Dont use WD40 it is a good lube but not a good penertrate. I hope this helps good luck
Old Sep 13, 2006 | 05:34 AM
t_lcohen's Avatar
t_lcohen
They are both 4wd. I tried everything possible to keep the shock compressed enough to get them on the bolts but with the angle it was just virtually impossible, lol. The bolts were not welded on the 99 but seemed to be on the 97 which is why I never removed the old from the 97.
Thanks for the advice.
Old Sep 14, 2006 | 01:25 AM
austinjorg's Avatar
austinjorg
I know its too late now but in the future I've always been ready to install the bolt, cut the wire compressing the shock and when it reaches the right point, stab it.
Old Sep 14, 2006 | 01:09 PM
89LX306's Avatar
89LX306
I had the same problem on my Super Duty when I put on my new Donahoe shocks. I dont' know if I was just extremely weak that day or what, but I could not keep the rear shocks compressed enough to get them mounted. I ended up using a jack to compress the shock and then that would get me close enough that I could wiggle it in. This was the 2nd set of shocks I put on this truck and this was the first time I had this problem. I probably spent over an hour on the rear two shocks. I tried pry bars, the strap that held them compressed, bench pressing the shock, everything...finally the floor jack method worked. You might need to let the suspension droop a little to help you further.
Old Sep 14, 2006 | 08:52 PM
t_lcohen's Avatar
t_lcohen
Been there, done that already, lol. Dropped the rear end down with the tire removed so much that the brake rotor was resting on the floor, lol. Tried floor jack too. And this set of front shocks did not come with the compressing wire attached to them like the rear shocks did.
Old Oct 18, 2006 | 07:48 AM
racerock's Avatar
racerock
What you can also do is use a strong string with a truckers hitch knot on them when they are compressed. Use the hitch knot to slowly let the shock out. Tighten up on the knot when it is where you need it for install.
sfc2001
22
May 9, 2023 02:36 PM
bismic
Jun 26, 2018 08:47 AM
ErrorS
1978 - 1996 Big Bronco
Jan 10, 2012 09:13 PM
996cup
Oct 27, 2011 06:38 PM
01silvergt
Mar 16, 2005 07:23 AM
