Sponsored by: Auxito
Power Window Problem
Old Sep 11, 2006 | 09:46 PM
kDemler's Avatar
kDemler
I've got a '98 F-150 (2wd) w/80,000 miles. The driver's side power window stopped working (in the down position of course). This happened after I left the running lights on for about 5-10 min. while the engine was NOT running. The passenger side window works fine along with all lights etc.
Could this be due to the battery saver relay or would that affect both windows? If so, is the relay located in the pwr dist box? Another bit of info, when I hit the window rocker, I get a click under the dash
Thanks in advance for any help!!!
kDemler
