Glow Plug Relay
Old Sep 11, 2006 | 04:14 PM
CheaperJeeper's Avatar
CheaperJeeper
Glow Plug Relay
I'm finding four different brands ranging from $16 to $36 at Schucks, and two at Napa ranging from $16 to $26. I've seen where several experienced people around here recommend one and ONLY one brand of glow plugs. Anybody have any good/bad experiences with the glow plug relays made by any of these six manufacturers?
MPE
Echlin
Niehoff
Borg Warner
Sorenson
Standard Motor Products
Old Sep 11, 2006 | 10:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Stock relay still doing fine on my 86.
Old Sep 13, 2006 | 04:33 PM
dyoungen's Avatar
dyoungen
I just bought an '87 F250 with a 6.9 Diesel and was wondering how long the "glo plug" light light is supposed to stay on? Mine stays on only a couple of seconds and is hard to start but once the engine is warmed up starts right away.
Old Sep 13, 2006 | 04:56 PM
CheaperJeeper
"STOCK" isn't one of the brands I was asking about, Dave
That sounds like a FoMoCo part that the stealership would want a hundred dollar bill for
Old Sep 13, 2006 | 06:25 PM
tjc transport's Avatar
tjc transport
i ain't rite
cheaperjeeper,
i wonder what the difference is between the $16 unit and the $26 unit. maybe the cheap one does not come with all the associated parts??
and dyoungen, it sounds like your glow plugs are burnt out. if your wait to start light is coming on at all, the controller is most likely OK.
Old Sep 13, 2006 | 07:33 PM
CheaperJeeper
Originally Posted by tjc transport
cheaperjeeper,
i wonder what the difference is between the $16 unit and the $26 unit. maybe the cheap one does not come with all the associated parts??....
Dunno'. What "associated parts" are supposed to come with a big honkin' relay? LOL! Replacement screws to hold it down maybe?
Old Sep 13, 2006 | 10:50 PM
Dave Sponaugle
All I can say is make sure it is a glow plug relay. There is a starter relay that looks exactly like the glow plug relay. I had a call from a fellow that could not get his glow plugs to work after he changed the relay. Turns out they sold him a starter relay. We had to change some wiring around to make it work and he was really happy that his truck started without being plugged in. That was fun troubleshooting electrical problems in a truck in Arizona from WV.
I can tell you the difference is a starter solenoid grounds through the mounting screws to energise the solenoid, but the solenoid is mounted on a plastic inner fender.
The glow plug relay grounds through one of the small terminals on the relay to energise the relay.
Look at the relay carefully, if it is a starter relay you will see an S by one small terminal and an I by the other small terminal. If you see that, it is the wrong one.
I use a lot of Echlin relays from NAPA and get good service from them.
88 F250 DIESEL's Avatar
88 F250 DIESEL
I Paid $180.00 From Local Ford Dealership For My 88 7.3 Glow Plug Relay.was Told It Only Came W/govenor In One Piece. Bob.
Old Sep 13, 2006 | 11:12 PM
CheaperJeeper
YOWCH! You sure it was the relay and not the controller. $180 sounds outrageous....
Old Sep 13, 2006 | 11:18 PM
88 F250 DIESEL
Got Info From A Ford Diesel Tech. Told Him When I Start The Truck, Neither My Wait To Start Or Water In Fuel Lights Come On. Also Noticed No Clicking Noise, He Said It Was Glow Plug Relay. He Said Runs About 90 Bucks. That Was For 98 & Up. 88 Was More.
Old Sep 13, 2006 | 11:33 PM
Dave Sponaugle
The glow plug system changed between 86 and 87.
The 83 thru 86 had the old style glow plug system.
The 87 thru 94 had the new style system.
They have nothing in common as far as parts go other than the names.
new style relay controller located on the back of the intake manifold
old style relay mounted on the inner fender
Considerable difference.
Old Sep 13, 2006 | 11:39 PM
CheaperJeeper
Hey Dave, if you wouldn't mind, I have a couple more questions I've been hoping you'd weigh in on in this other thread....
https://www.ford-trucks.com/forums/5...olution-2.html
johnboyky
Electrical Systems/Wiring
Feb 23, 2014 03:23 PM
FordLover18
Sep 8, 2009 11:28 AM
firebug
Mar 17, 2008 07:20 PM
Big Swole
Jan 16, 2008 06:56 PM
Bolliger
Apr 9, 2004 09:43 PM
