Glow Plug Controller Relay Wiring
Old Feb 23, 2014 | 12:17 PM
johnboyky's Avatar
johnboyky
I just bought a hard to start 1990 F250. Per the board, just replaced all 8 glow plugs with Motorcraft. Still wouldn't start (it turns over but will only start if you use either). I attempted to install a new BWD brand (Borg Warner I believe) glow plug connector relay today...I removed the old no problem, but am unsure what wires to plug where....the only connection that I'm sure about is the blue wire that works the WTS feature...it plugs in easily but I don't know if there are other connections that need to be made or not? All the wires run from the posts and into the bottom of the unit. Any help the experts can lend is greatly appreciated.
Thanks,
J
Old Feb 23, 2014 | 12:24 PM
Franklin2's Avatar
Franklin2
Does the picture below help?
Watch your volt gauge in the dash when you go to start the engine. If the glowplug system is working, you will see the gauge drop to 8v or below. They draw lots of current when they are working.
Old Feb 23, 2014 | 03:23 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
On my '05 it only drops to about 11.3v. Ya gotta have a battery in real good condition.
wtroger
Feb 2, 2011 11:39 AM
Chevy 6.2D
15
Feb 11, 2009 09:18 AM
Scottie250
Nov 15, 2006 09:11 PM
Lord Andy
May 8, 2004 07:40 AM
bigcedar6
13
Dec 10, 2003 09:25 PM
