Knocking ( Not the same old question )
Old Sep 11, 2006 | 12:14 PM
crew chief's Avatar
crew chief
Hi Guys,
I've been a member for a little while but never posted, I think i've read everything there is about the piston slap issue, My 98 Expo 4x4 5.4 has the classic cold knock on startup ( fairly audible ) but, it does not always go away, I can have the truck running for hours city and Hwy, and as soon as I get out for a listen at idle, there is the knock, not quite as loud but very audible. It get's lot's of love. Oil change every 3000-4000 km ( 10-30 Penz.) I've tried every oil filter there is. Tried synthetic, tried 5w20, tried lucas.. But the knock is there hot or cold 70% of the time. The funny part is sometime's the motor is absolutely quiet and just purr's at idle silently, So it's not a rod knock or anything major. I've had lot's of people listen to it and everyone says piston slap. I love the truck, it's still got good power and get's the milage it should. Just wondering if anyone is having or had the same issue?
I'm open to anything
Fantastic site, and thanks in advance.
Old Sep 11, 2006 | 07:42 PM
FTE Herman's Avatar
FTE Herman
I'd say welcome, but it appears you have been here for a while.
Could it possibly be that you are hearing an exhaust leak due to a broken exhaust manifold stud as opposed to the piston slap?
Old Sep 11, 2006 | 09:20 PM
crew chief's Avatar
crew chief
Thanks for the response, but It's definately not an exhaust leak.
I've heard many, the noise is intrenal, my thoughts were more along the line of possible timing chains. Can they make knocking type noises? How are they tensioned?
Again Thanks
Old Sep 21, 2009 | 08:18 AM
bcompton35603's Avatar
bcompton35603
I have a 99 Expedition with a 4.6, 224,000 miles that is making the same noise. I have been told that the timing chain will make a tapping noise because of stretch in the chain and wear in the chain guides causing too much slack. I really want to confirm this before I attemp to tear out the front of the engine to replace timing chains.
Old Sep 21, 2009 | 09:11 AM
alloro's Avatar
alloro
Try this thread to see if anything applies to your issue.
https://www.ford-trucks.com/forums/5...ain-noise.html
Pool Runner
2009 - 2014 F150
Feb 10, 2026 06:35 AM
timbo670
Modular V8 (4.6L, 5.4L)
Oct 26, 2012 01:28 PM
FxRiZBeAsTLy
Dec 11, 2010 10:45 AM
RobbyMartin
1997 - 2003 F150
15
Apr 21, 2010 05:37 PM
beekermartin
1997 - 2003 F150
31
Nov 29, 2007 08:10 PM
