I have a 1965 F-260 4x4. The plate underneath the back axle in which the U-bolts go too has broken apart and i just noticed it after I took the bed off for restoration purposes. I'm ready to put the bed back on and need to know where to get one. Any help is apreciated!!!! And I found a hedliner on jcwhitney.com that has speakers in it but it is for a 1967 and up. Is there anyway it would fit my truck because I would like to have something like it. THANKS!!!!
I am not sure exactly which item you are referring to, but if you are referring to anything to do with "axle mounting," I recommend you seek out assistance at a local spring shop. They have, can get, or can fabricate anything to do with attaching truck axles properly. Good luck.
