Offroad & 4x4
MAJOR swap
Old Sep 10, 2006 | 11:13 PM
78'fordman's Avatar
78'fordman
MAJOR swap
hey guys first off i have a 1978 F-100 2wd. It came with a 300 and a 3 speed manual. so far i have changed the rearend to a 9 inch with a spool. changed the drive shaft to a slip yoke. and the biggest change is i have changed the transmission to C-6 backed by a np 208 transfer case. i have put a 3 inch body lift on it and a custom steering shaft. i have 36x 12.5x 16.5 goodyear wrangler R-T II. my donor truck is a 1983 f-150 4x4 with a 351 windsor. my major question is will the front suspension go under my f-100? i know that on my f100 the steering knuckles tie rod end etc. are on the back side and on my f-150 they are on the front. i guess while im at it ill change it over to power steering. that help me out alot with steering. although i have to say that the manual box has held up good under some pretty harsh pounding. well if anyboy can help me out with any of these question or if tehy would like to see pics of my project so far just let me know. thaks guys
Old Sep 11, 2006 | 04:14 PM
Jmudder79's Avatar
Jmudder79
Whats your goal here? To make your truck from 2wd to 4wd? It would be alot easier to just buy a 4 wheel drive truck. The 83 has a completely different front suspension then the 78 4x4's did. MOre trouble than its worth IMHO.
Old Sep 11, 2006 | 05:33 PM
big hoss 29's Avatar
big hoss 29
If you're trying to swap your truck to 4x4, most people swap the IFS on 80-96 trucks for a solid axle set-up. Just throwing parts on a truck because you have them lying around is a nightmare and it takes more fabrication then you can imagine.
Save the money, and potential headache's and buy a donor truck that's the same year as yours so it's just a bolt in swap.
Old Sep 12, 2006 | 12:35 AM
78'fordman's Avatar
78'fordman
yeah my goal is to make it a 4x4. i dont want sumthign everyone else has. im mena think about it how many times have u seen a 78 with ttb 4x4 set up? my fab skills are more than up to par for this swap. i just wanted alittle info b4 i pushd on wiht my swap. another reason i wanted to keep the ttb is because i think it has a better ride to it than a solid axle
Old Sep 12, 2006 | 01:02 AM
big hoss 29
Well, IMHO, putting TTB in a 78 Ford would be like putting a turd on your finest China and serving it for dinner. A nice package, but it's still poo!
Old Sep 12, 2006 | 01:04 AM
78'fordman's Avatar
78'fordman
well what would be invovled in switching to a solid axle? and which axle should i use? i want to be able to thrash it but it hold up for a daily driver
Old Sep 12, 2006 | 06:13 AM
chrono4's Avatar
chrono4
well, if you want to be able to thrash on it, the ttb is not what you want.
Old Sep 13, 2006 | 06:09 PM
Jmudder79's Avatar
Jmudder79
None.
There is a reason for that.
Old Sep 13, 2006 | 06:12 PM
andym's Avatar
andym
Why's everyone always dissin' the TTB?
Old Sep 13, 2006 | 06:23 PM
chrono4's Avatar
chrono4
because imo under any kind of abuse, it wont hold a alignment, even though its the same thing as a s.a. 44 except for one extra u joint just seems weaker over all. Its a pain to lift and keep the frame from cracking at the drop pivots.
hivoltj
Sep 13, 2012 02:24 PM
dylan1952
Jul 22, 2010 09:30 PM
willburrrr2003
Jun 30, 2010 03:10 PM
elyons
Mar 23, 2001 01:23 AM
