Modular V10 (6.8l)
2000 V10 axle ratio
Old Sep 10, 2006 | 10:54 PM
Alwaysfixin's Avatar
Alwaysfixin
2000 V10 axle ratio
New post, same v10.
I was unable to find anything on the tag by the front door so I crawled underneath and read the tag on the rear axle. I checked my numbers twice. It is as follows:
3 S 138 H
73 10 5 0A26
None of these numbers match the info given to get gear ratio.
I then did the tach test.
At 75 mph I am at roughly 2150 rpm. It looks like 4.10 gears. Am I right?
Old Sep 10, 2006 | 10:57 PM
ptolalibertad's Avatar
ptolalibertad
thats about what mine reads.. i think yoiu have a 3.73 or something such as that. that seems to tach a little low for the rpm's..but i could be wrong. anyway , i do not tow or 4 wheeel, so i like my lower rpm's , means more mpg
Old Sep 10, 2006 | 11:45 PM
NoMo's Avatar
NoMo
Unless someone installed aftermarket ones, you have 3.73 gears.
Info on the door placard (sticker) is in "code". The information in This Post might help.
Old Sep 11, 2006 | 10:29 AM
Alwaysfixin
Thanks for the replies. After doing some more research I have to agree with you both. It must have 3.73 gears.
Thanks for the help and the info on this site.
Old Sep 12, 2006 | 09:19 AM
jwith68's Avatar
jwith68
Going by your RPM's at 75mph, I am pretty sure you have 3.73's. My 2000 has 4.30's and shows more like 2450 RPM at 75 mph.
The rear end tags don't have the same information they used to have, that is the ratio directly on the tag. However, my front diff tag does have the ratio on it. Have to get in underneath on the back side to see it. The door tag is the easiest way, but you need a cross reference from the code to the actual ratio.
Old Sep 12, 2006 | 11:00 AM
NoMo's Avatar
NoMo
jwith68, that info is still on the rear tag...
From Alwaysfixin's post, here's the info: 73 10 5 0A26
Obviously, it's missing the first "3" of "3 73"... that first digit is hidden under a bolt. If he had a limited slip differential, it'd show "3L73". And the "10 5" indicates it has a 10.5" ring gear. Not much else one needs to know.
For your truck, the rear axle tag will look similar but have 4L30 10 5 xxxx. Again, the "4" may be hiddin by a bolt head.
Old Sep 13, 2006 | 01:58 PM
Alwaysfixin
Thanks for clearing that up!
1982_f150
Mar 28, 2021 04:58 PM
mgraveman
Apr 24, 2017 01:31 PM
Selfhl1
19
Oct 23, 2015 08:44 AM
62FE4x4
Jan 26, 2014 02:18 PM
97tugger
Feb 22, 2010 06:21 PM
