Offroad & 4x4
.. a little sand running ..
Old Sep 10, 2006 | 10:11 PM
bremen242's Avatar
bremen242
I put together a vid of me and my peeps running the beach on the outer bankx.
I had the Escape wound up in first with 15psi in the tires. Was quite fun, I recommend it to everyone to try it at least once.. You swim around a good bit in the ruts, and there is no mud to clean up...
http://www.youtube.com/watch?v=5d8WAnpFAFc
Old Sep 10, 2006 | 11:12 PM
fishmanndotcom's Avatar
fishmanndotcom
looks like fun! were you in 4wd?
i am impressed there are still beaches open to dirve on!
-cutts-
Old Sep 11, 2006 | 08:12 AM
bremen242's Avatar
bremen242
It was, for sure.. About the 4wd, the Escape has that auto 4wd. It is FWD until it detects wheelspin, then it has a hydraulic lockup to lock in the rear. I'm guessing that it was probably in 4wd from the ammount of throttle I gave it. Only had a little bit of bogging when I went across some 1 ft deep ruts.
Actually, OBX has a couple beaches you can run.. Corrova (up north), the inlet (where I was at), and on Hataras Island (down south)..
Visseroth
May 7, 2010 02:46 PM
OutlawNomad
Mar 19, 2010 04:15 PM
monsterbaby
Iowa Chapter
Aug 21, 2009 05:17 PM
oneofakind97
Offroad & 4x4
Aug 9, 2008 11:22 PM
