sending unit
Old Sep 10, 2006 | 08:53 PM
Ford150/428/dud's Avatar
Ford150/428/dud
sending unit
After a two year restoration i finally got to fire my engine up today. And my fuel gauge doesnt work after filling it with 5 gallons of gas. I did the correct grounds and hookups. Is it because when i had the tank out i got the sending unit out of wack inside the tank because it was upside down during painting. Also i used a wiring harness off from a truck that the two fuel tanks. do i need to connect the tank selector to get my rear tank to work. Or to i have some other problem.
Thanks nick
Old Sep 10, 2006 | 09:43 PM
LxMan1's Avatar
LxMan1
You may have to cut out the front tank wiring and connect the rear tank wires to the wires running to the front of the truck.
Old Sep 11, 2006 | 02:56 PM
Mil1ion's Avatar
Mil1ion
The selector valve and the gauge work in conjunction with each other.
Turning it upside down shouldn't hurt it .
The wiring and switch conditions have to be perfect for the system to work properly.
So...Can you pull the S/U back out and then do bench test to verify it still works ?
see the 'center right' of this page.
http://www.clubfte.com/users/mil1ion...strations.html
Old Sep 11, 2006 | 10:35 PM
Ford150/428/dud
I cleaned all the connections and reconned all of the grounds, still no luck.
Old Sep 11, 2006 | 11:45 PM
Mil1ion's Avatar
Mil1ion
Did you check the signal wire (pulsing power wire)that runs to the S/U for the 5v of pulsing power ?
Did you ensure ground from the ground connector to actual ground ?
Old Sep 12, 2006 | 07:11 PM
Ford150/428/dud
SO i should be able to take a light up tester and check it at the sending unit to tell if it was the pulsing voltage. Ill give it a try.
Old Sep 12, 2006 | 08:35 PM
Mil1ion's Avatar
Mil1ion
Make sure the key is in run position when you do the test
Old Sep 12, 2006 | 09:31 PM
Ford150/428/dud
OK i did some reserch like i said before i used a frame wiring harness with the 2 fuel tanks i connected only the rear tank because my exhaust gets into the way of the second tank. If i reconnect the tank selector switch and the inline sylnoid to change tanks i should be able to get it to work. only thing is that i used the harness out of a truck with only the rear tank will i have the connection under my dash for the selector switch. I will check the voltage at the sending unit.
Thanks for the help
nick
Old Sep 12, 2006 | 09:45 PM
Mil1ion's Avatar
Mil1ion
Have you followed the wiring right down from the dash...or just from under the truck ?
I think you need to go right from the dash to the tank to ensure the proper no fault harness is being used.
I assume you are only going to run the ONE tank?
Old Sep 13, 2006 | 07:13 PM
Ford150/428/dud
Yes im only going to run one tank because of the dual exhaust, I will have to look it over this weekend because i have school all week long.
Old Sep 16, 2006 | 03:37 PM
Ford150/428/dud
Finally
I have got my fuel guage to work, I tested the rear sending unit for the pulsing 5 volts and there was none i figured that. So i found where the middle tank sending unit plugs into and tested it 5 volts of power. So i just ran a jumper to the plug in and cennected it and it worked.
Thanks for all the help!!
