Diesel camming ?
Old Sep 10, 2006 | 07:49 PM
kimf350's Avatar
kimf350
Diesel camming ?
When I first start up my truck it sounds like it has a cam in it. I have to keep giving it gas to make it smooth out . What is the problem ?
Old Sep 10, 2006 | 07:52 PM
powerStroker963's Avatar
powerStroker963
what is your weather like...myne will do the same thing if it is pretty cold out side ..its called "hunting" it is just trying to find the correct idle speed for that temp...
Justin Reynolds
#963
Old Sep 10, 2006 | 08:07 PM
kimf350's Avatar
kimf350
It's been hot here in Ga. It does it every time it is started up .
Old Sep 10, 2006 | 08:11 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
can you describe it as a "romp romp romp" noise? it is probably due to the fact that you run 15w-40 oil in a colder climate. due to the engine oil being thick when cold, it will not flow fast enough on startup by the pump into the high pressure oil system to stabilize the injectors. this gets worse as the oil ages. 5w-40 oil will fix this romping noise, and after so many miles, the sound will come back because the oil's additives wear out. i just changed my oil and the sound is gone again. the 5w-40 oil is thinner at startup and it flows better.
Old Sep 10, 2006 | 08:13 PM
powerStroker963
umm check ur cps sensor...it could be getting intermident signals..but get some more input form other guys on this forum tho....im new on here..im just telling you stuff that i have learned in school
L8ta
Jusitn Reynolds
#963
Old Sep 10, 2006 | 08:16 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Mine has never "cammed" as you call it. When it is really cold out, it will sometimes romp romp a few times but then a smooth idle and then on to the F16 jet whine until the truck is warm and the EBPV opens.
What are your temps out during the condition?
Old Sep 10, 2006 | 08:48 PM
lukecline's Avatar
lukecline
are you running a chip, certain programming can cause it to sould like a cammed up gasser. My extreme lopes for a bit then smoothes out.
Old Sep 11, 2006 | 07:32 AM
kimf350's Avatar
kimf350
I don't think it has a chip . When it first started I would use the diesel additive and it would clear up . So I think something is getting stopped up .
