Which tranny?
Old Sep 10, 2006 | 04:45 PM
Ford_Boy's Avatar
Ford_Boy
Exclamation Which tranny?
I have a problem. I have an 88 F-150 w/a very low geard manual tranny, but dont know which one it is. I dont even use 1st gear even thou it has one dead cyldr. Its only a four spd w/revers to the right and down. My other ? is that I may be geting my hands on a 460 to replace the 5.0 thats in it now but I would like to keep the four spd but I dont even kow if the bellhousing will fit. I have also herd of an eight spd spit-shift and would be interested to hear any info any one has on it. Thank you for taking your time to read and your help.
Joe
Old Sep 11, 2006 | 02:19 PM
'88_F-150's Avatar
'88_F-150
sounds like an NP435 but im not positive
Old Sep 11, 2006 | 03:22 PM
andym's Avatar
andym
Hey Ford_Boy, welcome to FTE. One thing is that the moderator likes to have descriptive subjects for posts... https://www.ford-trucks.com/forums/1...all-users.html
The 460 and the 302 share different bellhousing patterns. You would need to find a new bellhousing for that motor. Shouldn't be too hard to find at the junkyard.
The tranny could either be a T-18 or an NP 435. Both trannies are four speeds with a granny gear. If you crawl under the truck and look at the tranny, it will have "Borg Warner" cast into the driver's side if it's a T-18. There will probably be a round metal tag somewhere on it if it's an NP 435.
A gear vendors unit is what you're talking about in the last question. Search the axle forum here on FTE for more info - it's been talked about quite a bit before.
Old Sep 12, 2006 | 12:09 AM
BADCAR's Avatar
BADCAR
Looking for a FORD DIESEL
I had it w/ the GAS Gusslers I*M an OLe trucker & need all your HELP in finding ME & Mother a Diesel pick UP & an Older modle w/ NO computer stuff Reg CAB 2 wheel drive is OK! it don*t have to be Fancy just relibable Transportion one in need of a little Tinkering Ok as I*M retired & Well WE can*t afford the Newer models on a fixed income so Whos got One they Don*t use any more? or perhaps? they have Up Graded & the Dealer wouldn*t allow them what its worth? & I Dono? here all the Dealers are BIG & Whole Sale all their Used Vehicles & WE Not being Dealers are Shut Out infinding a Used One!--So HELP! HELP! Thanks Guys in advance--BADCAR--
Old Sep 12, 2006 | 08:17 AM
MustangGT221's Avatar
MustangGT221
Thanks andym.
Old Sep 12, 2006 | 06:53 PM
Cheggie's Avatar
Cheggie
Old Sep 12, 2006 | 07:43 PM
BADCAR's Avatar
BADCAR
Originally Posted by Cheggie
SORRY! if your reply is pointed at ME? as I*M New here! & Dono? where? I should Post?--as I*M old & a bit Tired & in a Hurry to get Answers! perhaps? a moderator will move IT to where it Belongs! again SORRY!--Ole JIM-
Old Sep 13, 2006 | 03:20 PM
andym's Avatar
andym
No problem Justin. Just let me know if I overstep my bounds.
BADCAR, yep, he was talking to you. If you PM Justin and ask him nicely, he may split your post off into a seperate thread. Or you could do it yourself by posting a new thread.
Generally speaking, threads are dedicated to one user's question/problem. If someone has a similar problem, a new thread is a good idea. If the problem is unrelated, then you definitely need a new thread.
If you look at the main forum page, there will be a button that says "New Topic". That's how you start a new thread.
Good luck & enjoy FTE.
