Carb problems with 4.9L
Old Sep 9, 2006 | 11:22 PM
Beater86's Avatar
Beater86
My 86 F150 started giving me problems today... I popped the hood and there was gas pooring out around the carb The truck seems to run fine when the rpms are above 1500, probably because the a/f isn't too far off. But below 1500 the thing just stalls out. I think it is flooding out. Would a bad float in the carb cause these problems? I will be pulling the carb either way to try and figure out what the deal is.... any advice?
Old Sep 10, 2006 | 11:13 PM
Piffery1's Avatar
Piffery1
Likely the float or float valve is the problem since the float valve is apparently staying open for some reason. Float full of gasoline is a suspect.
Old Sep 11, 2006 | 06:20 AM
Beater86's Avatar
Beater86
Piffery1... I forgot I posted this in two sections. It turned out to be dirt in the valve seat. I cleaned that and the float bowl out... ol' red is running much better now
