NP 203 Question
I am a fairly recent user and I love this site.
I have a 76 highboy aquired in June with an NP 203 TC and locking hubs. How can I tell if this TC has had a part-time conversion or not without looking inside?
Also, I think I read in one post that the chain can be replaced without dropping the TC. Is this correct?
Another thing, When I put the TC in low (not sure which low, very hard to shift) it worked fine the first time. The next time, it popped real loud and kicked back out. Could that be due to the chain?
I drive a Ford because I want to go everywhere my Tonka would go.
Mine poped out of 4wd on me one time, and had to get pulled out the hole about 4 feet. Man I wish it wouldn't of popped out(for more than one reason), but I was just about out.
Any, I got pulled out, unhooked the strap, and started driveing away, and it popped back in 4wd.
Needless to say, my front driveshaft broke, swung and cracked my trasmission, and it went down hill from there.
I hate the shift linkage. It is almost impossible to adjust the 4 linkages perfectally for it to shift like it is suposed to.
IF it has a part time kit, the the shift pattern would be
4wd lo
2wd lo
N
2wd Hi
4wd Hi
So you could put jackstands under all four corners of the truck, and put it in 2wd hi, and put it in drive with the front hubs locked it, and if the front tires don't turn it has the part time kit.
I don't know if the chain can be replace while the tcase is still mounted, but if it hasn't been done, then it prolly needs to be even though it doesn't seem like it has to much slack.
Now there are 2 part time kits, and it might be worth knowing which one would be in there.
One is a couple crown gears that get rid of the spider gears in the t case, and if that is the one installed, then you'd want to take it easy off road, b/c they don't hold up well to hard abuse.
The other is a solid shaft, and this is of coarse the better coversion, very strong and dependable.
Any more questions, I'll do my best to help, along with the other very helpfull people.
I've already got the front on stands. I'll raise the back and give it the part-time conversion test. Would the truck have had original locking hubs along with a full-time TC?
I'm gonna try adjusting the linkage. I just found that in my manual.
I'll probably have more questions as I go.
BTW, nice Bronco!
The trucks didn't come from the factory with locking hubs.
If you think you can adjust the likage then go ahead and try, but try and mark where it was to start with, with a marker, paint, or somthing. I messed with mine a couple times, and get the low to high shift to work real nice, but the 4wd wouldn't catch, so I ended up disconnecting the linkage that switch 2wd to 4wd and would crawl under and manully put it in 4wd.
Good luck.
IF your 203 shifts into 4wd ok and holds, then it should be fine, but I can't take it, mine gave me to much trouble. The only down sides to the 203 is the weight, linkage, and the chain driven part. But even though it is chain driven, it is still pretty strong.
If I were you, as long as it's working, I'd keep it, but if it gives you trouble, the first time you have the time to swap, it'd a great improvement, expecially since you have a donor truck with all the parts.
another easy way to tell if it has a parttime kit-
if you unlock the front hubs, and go nowhere in drive=full time.
plus, trucks with full time tcases normally have drive slugs in the front.
They both basically have the same 2:1 low ratio, but you might be thinking of 2 low, which sounds good, but I've never used it for anything other than to dig some holes while power brakeing.
( scratching My head ) Im still trying to figure out where I got the idea that they were different ...... I Apologize for any confusion
