standard flywheel
Old Sep 8, 2006 | 09:16 PM
scott haller's Avatar
scott haller
standard flywheel
dose anyone know if a351m flyweel to a 460 wheel work
Old Sep 8, 2006 | 09:53 PM
plowpusher's Avatar
plowpusher
no it will not work
Old Sep 8, 2006 | 11:09 PM
LxMan1's Avatar
LxMan1
I think a 390 Flywheel will work.
Old Sep 9, 2006 | 03:35 PM
RTM's Avatar
RTM
I have used the 390 flywheel but it can only be used on a 78 or earlier 460 motor.
Old Sep 10, 2006 | 01:06 PM
luckytruck79's Avatar
luckytruck79
Will the ring gear from the 390 flywheel work with the 460 starters?
Old Sep 10, 2006 | 03:36 PM
RTM's Avatar
RTM
This is where my memory has failed me. For the life of me I can not recall what starter I used on the 460 motor with a 390 flywheel. I am pretty sure that I used the 351M/400 starter because the car 460 starters have a soleniod motor to the starter.
If you have the old flywheel from the 460 just count the ring teeth and compare the count to the 390 flywheel. If the same then the starter will work fine.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
