rough idle 02 stroke
Old Sep 8, 2006 | 09:07 PM
emxmagnum's Avatar
emxmagnum
I have a 2002 stroke auto. The only mod is an edge EZ. recently i noticed that the engine had a rough idle (in both park and drive). The tach doesnt move much and it doesnt sound like its going to die...its more like a miss or its not getting enough fuel. Sometimes, this continues on up to about 1500 rpms when accelrating/decelerating. Removing the EZ doesnt change anything (may help a lil but its still there). I have changed the oil, oil filter, fuel filter, and have run a can of fuel treatement all since the problem started with basically no effect.
Any ideas on what it could be? I have searched the forums but was not able to find a description of my exact problem. I have a "blue" CPS on the way thinking maybe the CPS is going bad. Does this sound right? Anybody know what else it could be?
Thanks
Old Sep 8, 2006 | 09:18 PM
BowTieHatr's Avatar
BowTieHatr
bad injector, wiring issue. bad cps usually is intermitent shut off or a no start
Old Sep 8, 2006 | 09:42 PM
Uzumati's Avatar
Uzumati
any smoke when its rough, could be air getting sucked into the fuel lines
Old Sep 10, 2006 | 06:04 PM
emxmagnum's Avatar
emxmagnum
thanks for the replies. i havent noticed any smoke. if it was wiring or a bad injector, should i expect to a see a check engine light? would a diagnositc pull off any codes?
thanks again
Old Sep 10, 2006 | 07:10 PM
BowTieHatr's Avatar
BowTieHatr
if it is a contribution issue then probably no light. electrical issues can however throw the light
