'66 429 implant
Old Jan 27, 2001 | 11:15 AM
cowboy66's Avatar
cowboy66
'66 429 implant
I just picked up a good running 429 out of a '69 Thunderbird. I keep getting told that I'm going to have to move the motor mounts to make it fit. The truck had a 352 but it was toast so I pulled it and put a built up 289 in. It used the same motor mounts without any problems. Is this true? Am I going to have to move the motor mounts.
I'm also undecided on what tranny to put behind it. I'm deciding between a C-6 or an AOD. I still have the original 3.25 gears and I'm not really concerned about gas mileage. I just do a lot of highway driving and I want the best performance possible.
Tarry L. Harper
True blue, through and through!
Old Jan 27, 2001 | 08:58 PM
jowilker's Avatar
jowilker
'66 429 implant
Tony, is your heart in good enough shape to run that 429 in a pickup. You might have such a testostorone rush, that it could lead to a heart attact. ;-)
John
jowilker
Club FTE since 01 01
NC Chapter
66 F100s
In the still cool hours of the night,
you can hear chevys rusting away.
Old Jan 27, 2001 | 09:43 PM
skip4274's Avatar
skip4274
'66 429 implant
Tarry.
Call Dennis Carpenter Reproductions for some advice. There are a lot of conversions like this. They sell Trans-a-dapt motor mounts and aftermarket crossmembers for the upgrades. I don't think you will have to move anything if you get the right parts.
However, John is right. You'd better get some testosterone medicine ready if you put that bad boy in your truck
Skip4274
4everFord
Old Jan 27, 2001 | 11:06 PM
whd507's Avatar
whd507
'66 429 implant
you need to get some motormounts and motormount towers from a 1973-79 F-series with a 460. thats the easy part. and AOD will not bolt up to a 429/460 so you would need the E4OD,with the associated computer and harness. (stick with a C-6)
this is a fun swap that uses the same radiator, and driveline (with a C-6)as stock. most everything you need would be found on a stock 460 pickup. you will also need truck manifolds, or you will have to cut a notch in the frame on the passenger side to clear a passenger car manifold. if you use headers, do yourself a favor and get a quality starter first. 3.25 gears will limit your T-bird engine (the best "normal" 429 BTW) to around 100 mph but you will arrive there pretty quick!! (3.00's are good for a pickup, they are often found in F-150's with the 300-6. 2.73's are good for highway cruising and are likely what the engine was used to in the T-bird)
Old Jan 29, 2001 | 12:51 AM
cowboy66's Avatar
cowboy66
'66 429 implant
I must have a "testosterone" problem, because as soon as I'm through rebuilding it, it will have 489 hard stomping ponies at the flywheel. And I am going with a C-6. I just ordered a TCI Street Fighter from Jeg's. Thanks for the advice though fellows.
Tarry L. Harper
Old Jan 29, 2001 | 06:00 AM
jowilker's Avatar
jowilker
'66 429 implant
Yup, It'll get you. :-)
John
jowilker
NC Chapter
66 F100s
Old Feb 13, 2001 | 01:28 PM
joeteasley's Avatar
joeteasley
'66 429 implant
I have An 66 F100 with a 460 in it and the motor mounts were taken out and replaced with mounts that are welded in, but I found a kit from LMC. (www.lmctruck.com)the kit is for a 429 or 460 and it bolts in. the part number is 45-0368 and it cost $150
Old Sep 14, 2001 | 11:07 AM
flash429's Avatar
flash429
'66 429 implant
Tarry L. Harper
Old Sep 14, 2001 | 11:29 AM
flash429's Avatar
flash429
'66 429 implant
Cowboy66,
I thought I was reading my message before I wrote it.I also have a 66 f-100 shortbed and going to put a 72 429&C6 in. and removing the 289 that runs great.Iam in luck because I just picked up a 77 4x4 with 460 in it.It was free good for parts only.Good luck and keep it between the lines. Flash
Old Sep 16, 2001 | 11:19 PM
truckfarmer's Avatar
truckfarmer
'66 429 implant
I have a 69 429 Thunderjet and C6 that I want to put in a truck. I don't think I can handle all that testestorone. I would sell the combo for $350. It is still in the Thunderbird and I am located in Illinois.
Old Sep 27, 2001 | 11:15 PM
flash429's Avatar
flash429
'66 429 implant
[font size="1" color="#FF0000"]LAST EDITED ON 28-Sep-01 AT 00:18 AM (EST)[/font][p]Michael Noland
Will motor mounts from a 73-79 F series 4x4 work when putting a 429 & C6 in a 66 F-100?
The 4x4 is a F-250
Old Oct 2, 2001 | 02:40 PM
maharashii's Avatar
maharashii
'66 429 implant
truckfarmer,
ygm regarding that 429/C6. I may be in the market
take it easy,
maharashii
Old Oct 2, 2001 | 09:10 PM
Bill_Beyer's Avatar
Bill_Beyer
'66 429 implant
The 4x4 is a F-250
Well considering that 70s 4X4s never came with 460s you may or may not have a problem. The biggest engine you could get in a 73-79 4X4 was a 400.
Old Oct 3, 2001 | 11:10 PM
truckfarmer
'66 429 implant
I know of a 79 F250 4x4 with a 460 in a local junkyard right now. I assumed it came that way.
Old Oct 6, 2001 | 12:22 AM
Bill_Beyer's Avatar
Bill_Beyer
'66 429 implant
Nope...4X4s didn't get 460s 'til after the 351M/400 was phased out in '83. If it's a 460 then it's a transplant.
