mtjsdad
Old Sep 8, 2006 | 03:01 PM
mtjsdad's Avatar
mtjsdad
mtjsdad
please help...i own a 97 expy with 153,000 miles. when my cel came on i had a ford dealer scan it and it showed 2 oxy sensors going out and the mass air flow sensor. i replaced them but the light came back on about a month later. then without notice when i pulled up to a stop light...the engine died. i managed to limp home by starting the engine and shifting from neutral to drive by giving it more gas so as not to stall. i got online and checked some forums and most indications pointed to the pcv valve and iac valve. i replaced both and it worked. the cel was off so i took it to drive about 30 miles to reset the computer. i got 7 miles and it died again at a stop light. the truck starts right up and doesnt stall until i put it in drive. can someone help
Old Sep 8, 2006 | 03:09 PM
chrono4's Avatar
chrono4
well it showed those codes before, whats it show now?
Old Sep 8, 2006 | 03:16 PM
mtjsdad's Avatar
mtjsdad
i have at home with no way to check the codes. its to hairy to drive it anywhere when it dies
Old Sep 12, 2006 | 12:27 AM
NoMo's Avatar
NoMo
When was the last time you changed the fuel filter?
