Filter Cover Leak
Old Sep 8, 2006 | 12:07 PM
Zerojunk's Avatar
Zerojunk
Filter Cover Leak
Has anybody else had a problem with their oil filter cap leaking.I have change the oil.The dealer has changed the oil.I bought a new cover .Had the dealer change it again.Seems like one of us would have gotten it torqued correctly.Always blows oil up on the underside of the hood.Not a lot and probably not enough to hurt anything,but it aggravates me.Wonder if the filter housing casting is out of tolerance?
Old Sep 8, 2006 | 12:09 PM
dschuffert's Avatar
dschuffert
I haven't had any issues with it. I have had 4 oil changes to date. Each time I replace the O-ring.
Old Sep 8, 2006 | 04:04 PM
kw5413's Avatar
kw5413
Hope this helps.
Oil Filter Lid Leaks:
To prevent leaks from the oil filter cover, be sure to replace the sealing o-ring when performing oil changes. Torque the cover to 18 ft/lbs. If leaks continue to occur, check the housing for burrs and the lid for damage. If using an aftermarket filter, try a factory one. Broadcast Message 3403.
6.0 PowerStroke Fuel Filter or Oil Filter Housing Leaks:
The following parts are now available to correct leaks at the fuel filter and oil filter housings:
Primary (frame) Fuel Filter Housing: 3C3Z-9N180-BA
Primary Fuel Filter Cap: 3C3Z-9G270-BA
Primary Fuel Filter O-ring: 3C3Z-9364-BA
Secondary Fuel/Oil Filter Housing, <9-30-03: 3C3Z-9C166-AA
Secondary Fuel/Oil Filter Housing, 9-30-03>: 4C3Z-9C166-AA
Secondary Fuel Filter Cap: 3C3Z-9G270-AA
Secondary Fuel Filter O-ring: 3C3Z-9364-AA
Oil Filter Cap, F-Series: 3C3Z-6766-CA
Oil Filter Cap, Econoline: 4C2Z-6766-BA
Oil Filter O-ring: 3C3Z-6840-AA
Broadcast Message 3744, 3743, 4683
Old Sep 8, 2006 | 09:13 PM
BowTieHatr's Avatar
BowTieHatr
i bet the oil "leak" is actually coming out of the cac boot at the turbo. here oil vapor is pressurized with the boost and yes it does come out of the boot. they redesigned the boot to help this.
the oil filter housing may get wet around oring but it will never make it to the hood. no enough pressure.
Old Sep 8, 2006 | 09:56 PM
Zerojunk's Avatar
Zerojunk
Well,It's a 2005.Has 11500 miles on it.I usually drive it when I am hauling a tractor.It seems to do it worse at higher rpm and boost pressure.Takes it several hundred miles ,but it will get the bottom of the hood and the cowling at the top of the firewall oily.But,it leaks to slow to see where it is coming from.
Old Sep 9, 2006 | 07:08 AM
50jd60's Avatar
50jd60
Have the dealer put dye in it and have them check it with the light and see where its coming from
Old Sep 9, 2006 | 09:24 AM
BowTieHatr's Avatar
BowTieHatr
how bout clean it off and get the boot replaced. the interior portion of the boot is silicone sealed to help.
cubman61
Modular V10 (6.8l)
25
Dec 6, 2012 11:55 AM
bamacommander
2009 - 2014 F150
Dec 27, 2011 09:40 AM
Als03FX4
Jun 28, 2007 11:53 AM
cdrmotorsports
Mar 20, 2007 07:40 AM
kjw84fxr
Sep 19, 2003 04:24 PM
