I have a 2003 F-250 Superduty with 7.3 Powerstroke, auto transmission and 4X4. The left manual locking hub will not release unless I hit it with a rubber mallet. Once unlocked it is fine until I lock it, then to unlock, its the rubber mallet again. I want to remove the hub and try to clean and re lubricate, or replace it if needed. I cannot find a way to remove it. I removed the wire clip inside the housing, but it still won't budge. Is there another device holding it in place? Even the local Ford dealership claims they don't know, (or just won't tell). I have removed many F-150 and Ranger hubs, but this is nothing like the smaller hubs.
Can anyone help?
Thanks.
Its corrosion , soak the hub with pb blaster in and around the groove you removed the the snap ring from.
You may destroy it getting it out, use a heavey rubber mallet to smack it back and forth it will come out.
Been there don this on many trucks.
Rich
The driveline specialist that is converting my axle gears mentioned to me that when they remove the hubs, 90% of the time the seal breaks... Don't know if that helped any.
Reason: typo
Rich
if its only the corrosion holding it in what else can be done? I have beat on it and its all busted up. I have soaked it and it turns but wont come out
