96' gauge cluster swap
Old Sep 6, 2006 | 10:36 PM
CoffeyDye's Avatar
CoffeyDye
Exclamation 96' gauge cluster swap
i want to change my gauge cluster in my 96' 4.9 liter, with out tach. from a 95 f-250 351 with tach. will i need to run a wire to the tach? does the tach read from the computer? and what all do ya'll think i might need to change out??
Old Sep 7, 2006 | 07:52 AM
KW160's Avatar
KW160
Take a look at this article:
https://www.ford-trucks.com/article/...Or_Bronco.html
Also, note that while the 95 cluster will swap to 96, the wiring changed for the ABS lite in 96. What this means is that the 95 cluster will have the ABS lite on all the time and your ABS will not work. Your best bet is to find a 96 tach cluster to swap in.
Old Sep 7, 2006 | 08:46 AM
subford's Avatar
subford
https://www.ford-trucks.com/forums/5...hlight=cluster
It will tell you all about the cluster.
