Starter problem?
Old Sep 6, 2006 | 06:04 PM
austinpower's Avatar
austinpower
Starter problem?
About 2 times per week, when I start my 93 5.0L, I turn the key and it sounds like the starter is turning on, but does not actually turn the motor. When this happens, it does make a noise. If I move the key to the off position, it fixes itself after about the 2 or 3rd time I turn the key to the on position. Is it a starter problem?
Also, what kind of scanner do I need to pull the codes?
Old Sep 6, 2006 | 07:18 PM
mantta's Avatar
mantta
You need to put a new drive on your starter. The overrunning clutch in the drive is going bad.
Old Sep 7, 2006 | 08:57 AM
austinpower
Thanks Larry, I'll look into it.
