Broken Dipstick
Old Sep 6, 2006 | 04:55 PM
Hamberger's Avatar
Hamberger
Broken Dipstick
My oil dip stick broke off on my 7.3 N/A.
Has anybody had this problem before?
The dip stick broke right at the point were the flat part joins the handle and the flat part is now stuck in the dip stick tube.
Seb....
Old Sep 6, 2006 | 06:11 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yikes. Is it high enough that you can reach it wish the needle nose pliers?
Old Sep 6, 2006 | 06:12 PM
crazymike's Avatar
crazymike
i had this happen in mt ford taurus broke off right at the handle while we were replacing the engine. pulled it out by grabbin it with a pair of needle nose pliars and well pulling it was probably just a little old and finaly gave up -get yurself a new one...i guess
Old Sep 6, 2006 | 07:05 PM
dieself250's Avatar
dieself250
Last time i snaped a dip stick, i just took out the nuts holding the tube to the head pulled the tube from the block and removed the broken stick from the other end
Old Sep 7, 2006 | 09:17 AM
Hamberger's Avatar
Hamberger
No luck fishing it out with a pair of needlenose pliers. It is down atleast 5 inches.
I just hope I don't end up having to remove the starter or something like that to get the new tube back in. I guess I will look at it on the weekend.
Seb....
Old Sep 7, 2006 | 11:11 AM
fellro86's Avatar
fellro86
If you can get the tube out intact, just buy the stick. It can be pretty tricky getting that tube in if you buy it new, took a lot of monkeying around to get it done on the old man"s 84. I wish it was as easy as undoing the nut and taking it loose, but they are like the gas motors, almost press fit into the block. I highly recommend taking the batery cable loose before trying to put the tube in, can make quite the pretty arcing if you short the cable...
Old Sep 7, 2006 | 02:55 PM
Hamberger's Avatar
Hamberger
Thanks,
Very good point on the battery cable. 2,000 CCA can give you quite a bit of fireworks.
Seb....
Old Sep 8, 2006 | 08:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
And that nice flash will be the end of your tube and the new dip stick if it is in there.
There is an O ring on the dipstick tube where it goes into the block to keep it from leaking.
Old Sep 8, 2006 | 11:32 PM
muddingmcdude's Avatar
muddingmcdude
yeah not fun my 7.3 idi turbo broke down there cuz of there wonderful design a new one was like 70$ cuz u had 2 get it from ford u prolly wont get it out either i broke my dipstick tube 3 times tryin to get it out... i was PISSED lol
Old Sep 11, 2006 | 10:06 AM
Hamberger's Avatar
Hamberger
Well I got it fixed.
To pull the old tube is easy, disconnect the batteries and remove the one 3/8" screw that holds the tube onto the rockercover bracket and pull the tube out.
Rather that spend $70 on a new tube and dipstick I brazed it back together. It now is stronger that before.
I also went to my other truck and brassed it before it has a chance to break.
If you ask me the factory dipstick design could use this improvements, especially for guys like me who check there oil probably more than most people do.
Getting the tube back in is a two-man job. Dad helped me guide the tube from the top and I went underneath with a long scredriver to guide it in the hole on the block. There is just enough room between the starter and the hole to see what you are doing. The only other way I could have done it is to pull the starter motor.
Thanks for all comments and suggestions.
Seb.....
Thanks for everones help
