Gears
Old Jun 9, 2001 | 09:21 PM
1966blueford's Avatar
1966blueford
Gears
What would be a good gearing choice for a 1966 ford f-100. I want ALOT of torque but I want some speed also. It is a daily driver. I was thinking around 3:83? or something along those lines any suggestions?
Thanks
Old Jun 9, 2001 | 10:59 PM
fomocoloco's Avatar
fomocoloco
Gears
my 66 sb 428 c6 with 3.50 trac-loc i find to be a little low. i am not comfortable running at 3000rpm constantly to keep up with the traffic on the highway. i like the stoplite gig but i think i would be more comfortable with 3.25 or 3.00 instead of the 3.50's for highway driving. tires are quite tall also. i would guess my gas mileage to be 5-8 depending on how hard i hit the holley. just my take. jim.
Old Jun 10, 2001 | 06:29 AM
jowilker's Avatar
jowilker
Gears
David, In 66 the 352 and auto came with 3.00 gears. Plenty of power with some mpg. You might have to have a tire store card to run a gear like that you were thinking about, they wouldn't last long.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Jun 10, 2001 | 09:06 PM
mattb's Avatar
mattb
Gears
i run 4.10 in my 65 with a 352/c6, it runs about 3000 at 70 mph, take off is great, and it still has enough top end to keep ,up with just about anything. i also run 33" tall tires. depending on your tire size i would say a 3.73 would be a good all around gear.
mattb
Old Jun 11, 2001 | 03:34 AM
jowilker's Avatar
jowilker
Gears
Matt, your speedo is way off man. That 352 will be turning a lot higher at 70 mph than 3000 rpms with a 4.10 gear. Mines turning 24-2500 with a 2.75.
John
jowilker
66F100s Rule
Old Jun 16, 2001 | 10:47 AM
mattb's Avatar
mattb
Gears
John, that 3000rpm at 70mph was passing one of those police radar traps they use up here in WI. they just tell you how fast you are going, i was doing 70mph past one at 3000rpm. remember i have 33" tall tires.
matt
Old Jun 16, 2001 | 12:25 PM
Charles-65F350's Avatar
Charles-65F350
Gears
John, I think he is about right. I have 32.5" tall tires, with 4.88 gears, and turn 3025 rpm at 60 mph. Calculated and confirmed with my new electronic S-W tach.
If you run the math (1 revolution is 3.14 times the tire height, 60 mph is 5280 feet in 1 minute, etc) you should find that 33" = 8.64 feet per revolution, 70 mph = 6160 feet per minute, thus 6160/8.64 = 713 wheel rpm times 4.10 gears = 2923 driveshaft rpm with a 1:1 high gear, plus a little for converter slippage.
Old Jun 19, 2001 | 08:13 AM
jowilker's Avatar
jowilker
Gears
I ran mine up to 3000 rpm on my trip and it was showing 82.
John
jowilker
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Jul 3, 2001 | 05:58 PM
yellow352's Avatar
yellow352
Gears
I have a 352 .030 over factory 4spd. 3.73posi. would like some input on what you thing a good tire size would be for performance and mileage in a 70 series tire.
Old Nov 8, 2001 | 03:40 PM
supercub's Avatar
supercub
Gears
I have a 262-6, and the Spicer 60 (Dana), has 4.10 ratio. I have no idea what rpm I would pull at 70 mph, but I rarely drive it that fast. Too loud. but the power is awesome. It really handles and drives so much better with a few hundred lbs in bed. I have had 1800 lbs of soil in the bed.
It gets pretty bad milage for a 6 cyl, with one barrel carb. Probably about 8 mph over including town.
Is that about right?
Old Nov 8, 2001 | 04:27 PM
66worktruck's Avatar
66worktruck
Gears
JRNEWMAN
Apr 4, 2016 11:24 AM
bguy
Sep 19, 2014 05:49 PM
1967leroy
General Automotive Discussion
Apr 3, 2014 07:49 PM
Gwol
May 16, 2013 04:48 PM
Leadsled91
Feb 18, 2005 05:54 AM
