gas gauge
Old Sep 6, 2006 | 01:43 PM
hurricane72's Avatar
hurricane72
gas gauge
hey yall, my gas gauge will only register a little above empty but i know i got half a tank of gas..my uncle says it may be the float but i took the sending unit/float out and it moves fine, its not stuck or anything. he also said it may be a short but if it was a short, wouldnt it not get any electricity? its gettin enough to show on the cluster but not enough to register the full amt of gas..any ideas?
also, my aftermarket radio wont stay on. It worked fine for about 2 weeks and then when i'd turn it on all it would do is flash on and off like it was hooked to a blinker. I checked and re-did the wiring and fuses and it still does the same thing. anybody had this happen before?
Old Sep 6, 2006 | 06:15 PM
Mil1ion's Avatar
Mil1ion
The Ford gauge system works on a Pulsing 5 volts combined with a ground-out.
In your case it is could be the resistor or bad ground.
With a test light or Sweep muliti-meter ...Test the fuel sending unit signal connector for 5V pulsing with the key on.
If that checks out fine..the problem is either the grounding of... or the resistor in the...... Fuel sending unit.
Old Sep 6, 2006 | 09:33 PM
Fritolay's Avatar
Fritolay
million didnt the 72's use a resistor of some form on the back of the instrument cluster itself??
Old Sep 6, 2006 | 10:03 PM
Mil1ion's Avatar
Mil1ion
Here's the 74 and earlier.
Old Sep 7, 2006 | 02:53 PM
hurricane72
hey thanks for the info...the 5V pulsation - with the test light blink or will it stay lit? and what would cause the panel lights to not come on with the headlights? i know some of the bulbs in it are good but the only one that lights up is the alternator light but the alternator's working...any ideas?
Old Sep 8, 2006 | 11:32 AM
Mil1ion's Avatar
Mil1ion
5v Pulsing means "intermittent" so no it would not stay lit.
It would flash.
Cluster lighting is controlled by the printed circuit.
Crumbling cluster backs
Faulty bulbs or bad contacts of the bulb sockets
Faulty or Dirty Printed circuit.
The Headlight switch rheostat has not be turned enough to light up the bulbs.
can all cause the lights to not light up.
If any of the dash lighting works,that usually means the headlight switch is okay and the problem is with each bulb.
Old Sep 8, 2006 | 03:31 PM
hurricane72
a buddy of mine has a truck a couple of years newer than mine and he loaned me his cluster so imma see if his will work as far as the lighting goes. maybe the gauge too? i'll let you know when i find out something
Old Sep 26, 2006 | 02:46 PM
improvement54's Avatar
improvement54
I have a question to add onto this if I could...
Where do I hook my tach light source wire to get the tach to dim with the instrument panel lights. I thought maybe I could hook it up to one of the wires on the back of the headlight switch, but I'm having trouble identifying the correct one.
Old Sep 26, 2006 | 06:40 PM
Mil1ion's Avatar
Mil1ion
Light blue/red striped wire.
Old Sep 26, 2006 | 11:20 PM
improvement54
Thanks a Mil1ion!!!!
