I don't know much about this truck!
I have recently purchased a 1979 F-250 Custom Explorer 4x4. What I do know is that the engine has been swapped out with a 460. It still has the original tranny and axles, a little surface rust and needs a lot of TLC. When I tried to do a VIN search the number is not long enough. Is there a secret to adding characters to make the VIN long enough to be searchable? Any help would be appreciated!
Just post the info and I'll decode it for you.
also please put the topic in the title
ie:Engine Code on Rating Plate
I'm suprised no one mentioned my page here.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
In 1981 a new Amercian standard for VIN#'ing was created ....it became a 17 digit code from the other Ford 11 digit code system.
Here is what I found out from my VIN:
Results for VIN#: F26HPEE4262
Model Year: 79
Series: F250 - 4x4 Pickup
Engine: 8 Cyl, 351ci (5.8L) 2bbl
Assembly Plant: St. Paul
Transmission: Automatic, Ford C6
Front Axle: ('78-79) P.S. w/adj col.
Rear Axle: 3.54 5300lb Dana 60
Granted the engine has been swapped for a 460, I believe the rest is right.
Model Year: 79
