Gauges reset when driving
Old Sep 5, 2006 | 12:02 PM
desmo's Avatar
desmo
Yesterday while driving all my dash gauges went dead for a few seconds then went to full scale for a second, and then worked normal. At the same time the radio died and came back on. This happen about 5 times during a 3 hour trip. 2002 F250 7.3l. Does any one have any thoughts?
Old Sep 5, 2006 | 05:39 PM
ryaneverk2's Avatar
ryaneverk2
Maybe a loose fuse? Check the fuse guide in the owners manual, and check out the fuse(s) for the instrument panel/radio. I don't know what it could be other than a loose connection somewhere.
Old Sep 5, 2006 | 05:44 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I had a Dodge Ram (don't shoot me!) a few years ago that used to do almost the same thing. It had an added quirk though in that when the radio came back on the volume would go all the way up and stay there, you could not turn it down and when you shut the truck off the radio would still be on. You had to pull the battery cable. I sold it to a guy that I work with and he had the radio (factory) swapped out and he says it hasn't done it since.
Old Sep 12, 2011 | 06:14 AM
bronco252's Avatar
bronco252
My truck is doing this now, did anyone ever find out what was causing this problem?
Old Sep 12, 2011 | 09:50 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
On the 2002 and up models, this is a tell tale sign of weak batteries, an alternator that isn't charging, or all of the above.
Make sure your battery connections are nice and tight. If they are, head to autozone and they can test your alternator and batteries while in the truck. Just make sure that when they test them, that one of the two batteries are disconnected otherwise you'll get a false reading.
Old Sep 12, 2011 | 12:17 PM
bronco252's Avatar
bronco252
Thanks Toreader_Diesel, I replaced the batteries about 2 months ago and the alternator about 5 months ago and when this happened I jumped out real quick and checked the alternator output and it was about 14VDC. I must have a corroded contact or something somewhere. All the connections are clean and tight, that was my first thought. I guess I'll just have to keep looking. Mine is a 2002 BTW...Thanks for the response...
Old Aug 18, 2012 | 07:22 PM
kornfanjoe's Avatar
kornfanjoe
My 05 ex did this earlier today but I have 2 brand new batteries and a brand new alternator. I have noticed that on wot my alternator puts out too much voltage and gets up to 15.1 causing my battery light to come on the dash.
Old Aug 18, 2012 | 07:35 PM
guitarpicr's Avatar
guitarpicr
Might check the ground connections at the frame as well- A loose ground could do this too-Take them loose & clean the eyelet terminal end & the frame.
Old Aug 19, 2012 | 01:00 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
My '02 was doing this, kept getting worse. Finally got to the point trans temp gauge was not working at all and check engine and glow plug light stayed on. Asked on here, talked with several Ford techs I know and no one had an answer. Replaced the dash cluster from a truck yard and no problems since.
websurfer
19
Feb 21, 2024 06:19 PM
pbruckne
6.7L Power Stroke Diesel
17
Jan 5, 2020 07:45 AM
old blue beast
Aug 5, 2016 08:28 PM
BleedFordBlue_Al
1997 - 2003 F150
Mar 6, 2016 09:33 PM
Surfcop
13
Apr 9, 2015 12:08 PM
