oil?
Old Sep 5, 2006 | 11:59 AM
TKKTommyboy's Avatar
TKKTommyboy
Question oil?
I have a freshly converted 390 (from a 360) my question is how many quarts of oil should i add to a 390 that has never been started to be at a safe level for starting?
I added 5 and the stick is reading high. is it truly high or is it just because the is nothing in the filter etc.
Old Sep 5, 2006 | 01:11 PM
rusty70f100's Avatar
rusty70f100
It's just because the filter is empty. Once that fills up, the level will be right on.
Old Sep 5, 2006 | 08:24 PM
pbear6969's Avatar
pbear6969
Tommy did you install a HV oil pump or stock? Just asking cause if you put the HV pump in it you need to run 6 quarts.
JMO
Old Sep 5, 2006 | 09:41 PM
rusty70f100
Really? I have a HV pump in mine, and I always ran 5.5 quarts. Of course, I'm also using a larger than stock oil filter.
Old Sep 6, 2006 | 02:57 PM
pbear6969's Avatar
pbear6969
I have been told you should run 6 with a HV pump. I don't know personally if it is required or not. I run 6 in mine, but I have the big oil filter, windage tray and a HV pump. Maybe I am doing it wrong??
Old Sep 7, 2006 | 10:04 AM
TKKTommyboy
JMO
As far as i know it is not anHV pump it is a melling replacement that came with the master rebuild kit.
Old Sep 7, 2006 | 11:00 AM
Redmanbob's Avatar
Redmanbob
I dont know but I always poor about 1/3 of a quart into my filter prior to installing it and wet the seal with fresh oil the hand tighten it. I heard tell "that it can create issues with it empty" never seen it as I've always done it this way.
Old Sep 7, 2006 | 11:26 AM
rusty70f100
My main concern with overfilling it (that's what you're doing when you put 6 quarts in a 5 quart pan) is that the oil level could cause the crank throws to whip the oil on odd angles or under acceleration. This forces air into the rod bearings... not good.
I'd say, add 5 quarts, break in the cam (since this is a new build), drain, change filter, refill with 5 quarts, run it for a couple minutes, turn it off, wait 2 minutes, and check the level. Add a little bit at a time until it's at the top of the full range on the dipstick. If you have 6 quarts or more at that time, fine. But dont go over the full mark. Oh, and be sure you're on flat level ground when doing this too.
Old Sep 7, 2006 | 01:15 PM
pbear6969's Avatar
pbear6969
Well I guess I was wrong after all. LOL Thanks for the info rusty70f100. I thought I had read on here somewhere to run 6 quarts with a HV pump because of the oil pooling in the head and not getting back down to the pickup fast enough. Glad you straightened me out. I am getting ready to change mine after I get it in the truck so I will try the thing you wrote above. I know it will take more than 5 but I don't think it will take 6. The windage tray adds the height of another gasket and the thickness of the tray itself. Thanks again!!
Old Sep 7, 2006 | 04:24 PM
charles jones's Avatar
charles jones
Mine reads full at 5.5 quarts with a stock oil pump.
blisstruck
Mar 21, 2012 02:37 PM
raywiseftm
Sep 30, 2007 12:24 PM
dj53
Feb 7, 2006 12:50 PM
ford390gashog
15
Jan 25, 2006 01:02 PM
ford390gashog
21
May 13, 2005 09:47 PM
