Sponsored by: Auxito
Theft/ignition switch problem
Old Sep 4, 2006 | 08:32 PM
jailcop's Avatar
jailcop
Post Theft/ignition switch problem
Please help with any info on a 2000 F150, 2x4, V8 4.6, battery dead this morining, recharged, noticed theft light flashing rapidly. Truck would not start, then it started, turned off, then restarted, theft light flashing again. truck stalled. Then started. Noticed that odometer reading was on when truck was in off position, showing only dash marks. Also the last month when turning off truck, the ac/heater blower would continue to run for approx. 10 seconds, then it would shut down. Please help with any info. Thanks guys
Old Sep 4, 2006 | 10:07 PM
BowTieHatr's Avatar
BowTieHatr
by any chance has it been raining? the gem modules on back of the fuse box inside is bad about getting moisture/rain inside causing all sorts of problems.
Old Sep 5, 2006 | 06:17 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome jailcop, to Ford Truck Enthusiasts!
See you on the boards. ….
