Newbie
Old Sep 2, 2006 | 12:52 PM
cruzin55f100's Avatar
cruzin55f100
Smile Newbie
i just bought a 55-f100 that sat in a farm for over 20 years. i got it to turn on it smokes a little but runs smooth, it has an auto transmission. it has the 239 v-8. i guess my question is should i keep this motor set up or go to a 302/460 set up. this will be a daily driver. i just want something that will be reliable. i know i will have a lot of questions later on but i figure i get the powertrain going first. also i am highly mechanically incline and have lots of tools so i dont mind doing the work myself. i just need good guidence since i have never did an older vehicle. thanks in advance.
Old Sep 2, 2006 | 01:04 PM
truckbuff's Avatar
truckbuff
Leave the engine & trans alone for now. Enjoy your running truck while you
learn more about it. Put some time & money into steering, brakes, tires,
suspension, etc.
If you do swap engines later your daily driver will not be a driver for a while,
so you have to factor in some down time. In the meantime you can get more ideas & info on what you want your truck to be when it's 'finished'.
Old Sep 2, 2006 | 01:47 PM
Gear Up's Avatar
Gear Up
Welcome to the board. Those that hang out around here are pretty knowledgable and willing to help in any way. I would have to agree that you should drive the truck for a little while to find out what needs work and give yourself some time to see what is out there for options. You can develop an engine while driving the truck and make the swap when ready. Good luck with the truck.
Gear Up
Old Sep 2, 2006 | 02:06 PM
cruzin55f100
i am about to do the brakes, it has drums at all corners, i had a 64' fairlane when i was in school and it also had drums which worked fine, should i stay with drums? i want to keep it as original as possible, but of course safety comes first.
Old Sep 2, 2006 | 02:11 PM
Randy Jack's Avatar
Randy Jack
I agree with what has already been said. I drove mine for a few years before going into the drive line heavily. The experience gave me a lot of good ideas and that saved a ton of money and time.
FWIW, The 302 is a dependable engine with lots of aftermarket and stock parts easy to find. It is a bit underpowered if you want a hot rod, but as a daily driver, it is a good choice.
The guys that all run 460's will tell you the honk!! Tons of torque and performance...lousy gas mileage. They also are relatively easy to get parts and accessories for.
A 351W (or 351C) might be a good compromise for around town power and good freeway cruising.
Good luck.
Old Sep 2, 2006 | 04:23 PM
GreatNorthWoods's Avatar
GreatNorthWoods
What you do with brakes should be determined by what you plan to do with the drive train. The old drum brakes were marginal so if you keep the 239 and original rear you aren't likely to get into too much trouble with the drums, but if you have any idea of updating the engine, trans, and rear or plan to make this a daily driver then the original drums will not be adequate. I'd go with disc brakes on the front even it you keep the original engine and transmission and later if you upgrade the rear to a nine inch it will be compatible.
Vern
Old Sep 3, 2006 | 10:11 AM
Gear Up's Avatar
Gear Up
If you are going to do the brakes you might consider power brakes. The old manual brakes had a tendency to fade when they warmed up. The old truck I am starting to work on has drums and manual brakes. The donor truck has power brakes which I will be transfering across. You didn't see disc brakes on vehicles until 69 and not all trucks had them until the early 70's. I know you can get conversion kits and it makes a great addition for stopping with disc brakes. Good luck.
Gear Up
Old Sep 3, 2006 | 11:01 AM
AXracer's Avatar
AXracer
Welcome! All good advice!
I'd also recommend paying close attention to the steering gear. The steering gearbox is the weakest link. If your's is tight, thank the powers that be and be sure to drain it and fill it with fresh lube. If there is a lot of freeplay or binding start deciding what route you want to take to fix it, you can rebuild or replace the box with a rebuilt one, a fairly pricey option that leaves you with safe but still "armstrong" steering, or possibly upgrading to power steering. check out this article for the various options: https://www.ford-trucks.com/article/...60_Trucks.html
Old Sep 3, 2006 | 11:20 AM
cruzin55f100
thanks for all the help guys, were do you guys purchase parts. i received a catalog from Sacramento Vintage, how are they?
Old Sep 3, 2006 | 11:40 AM
Bdox's Avatar
Bdox
If you have no experience with drum brakes you should know that if you drive through water they will temporarily become ineffective. The trick to avoid this is to keep your foot on the brake while going through the water. This keeps them hot so the water will boil off right away. (This alone makes a strong case for changing over to disks.)
Old Sep 3, 2006 | 12:16 PM
AXracer's Avatar
AXracer
I like Mid Fifty www.midfifty.com if you don't have one of their print catalogs, get it immediately! It has a wealth of info besides parts.
Old Sep 3, 2006 | 04:44 PM
59flatbedford's Avatar
59flatbedford
well it sound like your truck is all origanal so why not keep it that way.
Old Sep 3, 2006 | 06:22 PM
Bdox's Avatar
Bdox
That's a personal thing. Upgrades, (especially power disk brakes) can make an old vehicle more of a pleasure and safer too.
Old Sep 5, 2006 | 06:11 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Welcome to the board!!
Very good advice so far. I highly recommend driving it for a bit before starting anything major. The reason for this is that when you fall into one of those terrible ruts that befall each and everyone of us, you can look back on the good times you had in the truck. Trust me, it helps.
Now that you found this site you will always have helpt to get you through the tough spots also. Everytime I get down and out about the truck there is someone here to offer words of encouragement, merciless teasing, and general smart-alec comments to get my motivation back.
Glad to have you
Bobby
Shane Carruth
Jan 1, 2015 02:16 AM
D_pickup_55
Aug 8, 2014 05:58 PM
flatironfly
13
Nov 19, 2012 09:02 AM
drmgoat
15
Jul 28, 2007 02:14 PM
