Flapper door problems
Old Sep 2, 2006 | 12:13 PM
MSC's Avatar
MSC
Okay, after replacing the heater core (86 150 I6 w/ac), I don't have any defrosters. The only place I have air flow is through the vents. No matter where the selector switch is. With the heater core cover removed I can see the flapper door that controls the air flow between vent and defrost. When looking inside, I can see what appears to be a broken edge back by the mtr attaching point. It looks like a plastic flexible hinge that has broken. Not a pivot rod where the door would be attached. My door is free floating. When the selector switch is in the vent position the vacuum motor pulls on it, it will close the flow off to the defrosters. But when I switch to defrosters, and the vac mtr pushes on the door, it looks like it's not hinged. It moves about half way and stops. In my feeble mind it needs to be hinged...right? Any help???
psychlopath
15
Feb 1, 2021 10:32 AM
207charlie1369
1997 - 2003 F150
Jan 12, 2014 09:50 PM
abyars111
Dec 10, 2013 07:09 AM
mustange70
Jul 12, 2012 06:46 AM
