Another 4.0 upgrade question:
Name an upgrade or mod following installation of intake, exhaust and programmer that you consider worthwhile. I want to keep the ability to run 87 octane and that made the Bama a no-brainer. Airflow both in and out fo the engine also seem to be the only worthy upgrades I've seen. I'm realistic about the capability of the 4.0 SOHC, and just want to maximize it's ability while doing nothing to harm the reliability of the engine. I can't really think of anything else; headers seem frivolous, I'm pretty sold on synthetic blend at dino change intervals. I dunno... anybody?
I consider the e-fan conversion I did a total waste of money, and am seriously considering taking it off. The first fan I had (plastic blades) would warp when hot and go out of balance, so the whole truck would shake. Then i got a fan with metal blades, and the roll pin holding the fan to the shaft came out so the fan didn't actually turn. And when its hot out, it struggles to keep the engine cool...
The Bama tuner was a good investment. Several guys claim they gain more mileage from the 93 tune, so they actually spend less on gas then if they ran the 87 tune - I'm still testing the 87 so can't personally speak to that one yet.
If you run Mobil 1, you can go a lot more than 5k miles between changes - I've personally run Mobil 1 to 15k miles and had it tested - it still meets new oil specs after 15k miles in my tests.
If you have an 03 FX4, you should already have 4.10 gears. I know that was standard on the manual trans FX4, and I believe it was on the auto also.
