Door Mounting Bolts
Old Sep 2, 2006 | 11:37 AM
jfarcas's Avatar
jfarcas
Door Mounting Bolts
Hey guys, working on a '76 Supercab, and have to replace a door.
The bolts on the junkyard door came off pretty rough, and stripped the bolts as well as doing a number on the threads inside the door. I'm going to have to drill and tap them, so I'm wondering if anyone knows the tap size I should use for them.
Thanks!
JF
Old Sep 2, 2006 | 10:42 PM
plowpusher's Avatar
plowpusher
5/16nc use a 1/4 drill if the heads were 1/2 inch 3/8nc if they were 9/16 headed bolts pilot drill for these would be a 5/16 bit hope this helps
Old Sep 3, 2006 | 01:40 PM
Toolinaroundjpl's Avatar
Toolinaroundjpl
Unless you broke the bolts of in the door you should not have to drill them. Just run a tap in to clean the threads up. If the threads are to far gone than you are going to have to increase the size of the bolt in order to cut new threads. Speaking from experience I think just cleaning the threads up will do it. I am not exactly sure what the thread size is, but if you take a bolt to a parts store they should be able to tell you. good luck.
