cam break in
Old Sep 1, 2006 | 12:48 AM
dieselburner6.0's Avatar
dieselburner6.0
cam break in
ive just installed a eldelbrock performer cam into a freshly rebuilt (bored over with new rings / pistons, turned crank and bearings, and cam and lifters) the sheet that came with the cam says to run the engine at 2000-2500RPM for the first 30mins, any one else think them rpms are alittle high for that amount of time?
Old Sep 1, 2006 | 07:30 AM
greenhighboy's Avatar
greenhighboy
I recently broke in a Lunati VooDoo hydraulic cam and let it run at 1,800-2,000 for 20 minutes. I would say that 2,000-2,500 is too high.
I would HIGHLY recomend that you use Rotella 15-40 oil for your cam break in. Cams need zinc during break in, and Rotella is one of the few oils that still has it.
Old Sep 1, 2006 | 09:52 AM
carsbycarl's Avatar
carsbycarl
I have always done break-in at 2000-2500 rpms changing the rpms every couple of minutes.
Old Sep 1, 2006 | 11:35 AM
dieselburner6.0
thanks, the girlfriends grandpa said to use john deere break in oil, he figured that would be about the best for it.
Old Sep 1, 2006 | 03:31 PM
airharley's Avatar
airharley
Don't forget to keep an eye on the engine temp. If you start to get overly hot kill it and wait until it cools off before continuing the break in.
Old Sep 20, 2006 | 08:51 PM
austynn2001's Avatar
austynn2001
I called Lunati tech support for my new cam and they said 8 quarts of Shell Rotella 15W-40 at 2500-3000 RPM for a half hour. I've yet to do it (Sunday is the big day), but I'll let everyone know what happens.
ptboi94
May 19, 2011 09:20 PM
Shernius
Mar 3, 2005 08:26 AM
myst
Jan 26, 2003 11:53 AM
BroncoScott
1978 - 1996 Big Bronco
Nov 20, 2002 12:56 AM
broom
Nov 24, 2001 12:46 PM
