power steering problems
Old Aug 31, 2006 | 11:23 PM
sean23johnson's Avatar
sean23johnson
last week i greased all the balljoints in the steering and now the steering is so loose that i can spin the wheel effortlessly with my finger lock to lock. i dont think greasing the balljoints has anything to do with this because i have done it a hundred times before with out this happening. also when i am turning a corner the truck will not straiten it self out like it is supposed to do, i have to do it myself. it seems like the pump wont return the tires to center. i hope you guys understand what i am describing here because this thing is steering like a 40 year old caddy on ice.
Old Sep 1, 2006 | 09:55 AM
mueckster's Avatar
mueckster
Sounds like a problem in the steering box. The fluid may be bypassing inside. How's the backlash on the steering box? Does the steering wheel feel excessively loose or tight?
Old Sep 1, 2006 | 10:04 AM
sean23johnson
excessively loose. how would i check to see if the fluid is bupassing inside? i replaced the box a year and a half ago because it was leaking.
Old Sep 1, 2006 | 10:31 AM
Cuda_jim's Avatar
Cuda_jim
The pump does not return the tires to center. It's done with Caster. That's the tilt front to rear of the upper B-joint to the lower b-joint.
You have something worn out or binding in the steering and/or the suspension. It's possible for the pump to be holding it back from returning to center tho.
Old Sep 1, 2006 | 08:43 PM
sean23johnson
thanks guys, anyone else out there.
