90 efi 351w to 85 351w swap
I have a 1990 bronco with a efi 351w. I just purchased it for 200.00 from a guy I know. There is something wrong with the transmission. When you put it in gear it will only engage if I let the engine idle low. Anyway, I also have a 85 f-150 2wd that also has a 351w but it is carborated. Can I swap the 351w from my bronco into my f-150. I realize the entire fuel system will have to be outfitted to the 150 as well but I want to be sure the blocks will swap before I commit. Is there a difference in the transmissions due to the transfer case? Perhaps the tranny's will swap as well? I'm mechanically inclined and confident I can perform the swap but I'm not a veteran ford man and simply need an anwser to what the differences are in the two and if I can interchange them.
90 351 to 85 351
Thanks for the information about swapping out the engines. I took a look at the tranny fluid to see if it would show me any clues(like engine oil) and I was confused by what I saw. It looks like motor oil. Also I took it for a idle around the block to bring it to temp, and the dip stick was so hot I couldn't hold on to the stick for more than a couple seconds. Anyway, I just want to get one of the two vehicles running for now so, I'll go with the engine swap. Thanks again, I really appreciate the help.
