The tech at Banks told me that an intercooler on an older IDI with an add on turbo would not make any noticeable increase.... I'm not sure that is true or if he just meant that if you simply bolt on a banks turbo with no other modifications.....
Has anyone installed a water injection system?? I have read it does not in any way replace an intercooler but for the cost and labour of the the two, it lowers the EGT's and is a viable alternative.
Here is a picture of an intercooler going on a 92 that I downloaded when I was doing research on installing one on mine. I have internal engine mods and am running head studs with 20 PSI of boost on my 6.9.
The plumbing is a bit of a nighmare, but it can be done.
I found taking pictures was easier than trying to explain a lot of things, glad you liked them and they helped you. I have more I need to put captions on and upload, but I have been way to busy at work.
