My first fuel filter change!
Old Aug 31, 2006 | 01:11 PM
RUN52's Avatar
RUN52
I just completed my first fuel filter change on my 05 F250 4x4. I used the instructions from this site. Everything went very smooth I only drained out about two cups of fuel there we're no messes or any problems. I did pour in some stanadyne in the secondary housing as per the instructions, I assume this helps with repriming the system. I didn't bother jacking up the drivers side front axle as it didn't seem to be any help. I purchased the filters from the Powerstroke Shop and saved a ton of money compared to the dealer. My dealer wanted over $190.00 to change my filters so the total savings was quite large. The savings was enough for me to get another torque wrench! which is a good thing. Thanks to the F.T.E. website and all of the users who shared all thier info. weather good or bad.
Old Aug 31, 2006 | 01:56 PM
Lonewolftx's Avatar
Lonewolftx
Thumbs up Great Job . . .
U can also get them at the International Truck/Navistar dealer as well for around $31.00http://www.internationaldelivers.com...rs/locator.asp
Congrats!
Old Sep 1, 2006 | 06:40 AM
benbishop's Avatar
benbishop
Exclamation
Ironically I just completed my first change on my friends '03 last night as well. Unfortunately it didn't go as well. Everything went fine. Finished up and started the motor. We let it Idle for about 10 min and it sounded perfectly normal. Shut it down for about an hour so we could install his headache rack and toolbox. He started it back up so he could leave and it was running a little rougher than normal. Then it almost stalled and he shut the key off. After that we couldn't get it started again. Just cranks and will seem to start for a sec...but then not. Any Ideas on what to do would be very apreciated!
Thanks,
Old Sep 1, 2006 | 07:50 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Thanks,
What brand of fuel filter did you use and where did you buy it?
You have air in the system... either an improperly installed filter, a filter which does not fit correctly, the cap on either filter housing is not on straight and on all the way (check the large HFCM filter which is normally the cause) or the O-ring for either filter is not lines up 100%.
That should be it.... but some aftermarket fuel filters do not fit 100% as OEM ones do... and buying them from your local int'l dealer is the least expensive too.
Old Sep 1, 2006 | 07:53 AM
benbishop's Avatar
benbishop
The filters were Motorcraft brand from Advance Auto. I will try removing and reinstalling the filter on the HFCM tonight.
Old Sep 1, 2006 | 08:07 AM
Beachbumcook
Got Diesel?
Then it is air in the system or a small air leak.
Check your large filter to see if the cap is 100% on... they get kind of stuck or hard to turn... yet have not seated 100% on to the assembly housing.
Good luck,
Old Sep 1, 2006 | 08:15 AM
benbishop's Avatar
benbishop
Ok I'll check that. I was worried because the directions I read said only 19ftlbs for the HFCM cap...which isn't too much.
Why would it Idle for 10 min and then start seeing these problems? Just wondering.
Thanks for the help!
Old Sep 1, 2006 | 08:19 AM
Lonewolftx's Avatar
Lonewolftx
Arrow Bummer . . .
Haven' fun yet? Not to laugh but doing these for the 1st time can be APITA!
Old Sep 1, 2006 | 08:26 AM
benbishop's Avatar
benbishop
I feel worse cause it's not my truck. I'm pretty proficient with gas vehicles...this is the first diesel i've done work on. He's driving my '76 GMC today and truck is sitting in my driveway. Hopefully I can get home this afternoon and re-doing the filter on the HFCM/making sure it's seated better will fix it. Makes me not want to buy a diesel...haha.
Old Sep 1, 2006 | 08:32 AM
Lonewolftx's Avatar
Lonewolftx
Thumbs up
You'll get it, NO WORRIES!
Old Sep 1, 2006 | 09:02 AM
benbishop's Avatar
benbishop
Hopefully I can get the thing running tonight before the rain from Ernesto gets here. Thanks for the ideas and encouragement.
dub300000
Oct 10, 2014 09:36 AM
twabscs
1997 - 2003 F150
Mar 16, 2008 09:43 PM
CowboyHokie
2004 - 2008 F150
Jul 16, 2007 04:18 PM
TeamMudd
Modular V10 (6.8l)
22
Nov 16, 2006 06:26 AM
olfordsnstone
Jun 14, 2006 08:02 AM
