NEW CPS & FIXED EBP BUT STILL SKIPPING
my grandfather has a 2000 7.3 excursion and it is sick. when you punch the throttle it runs great but when the rpms come down it will start to skip and sometimes turn off - it has a new ipc sensor, cps, and i put an ebp eliminator on it yesterday b/c it threw that code - it sound like the enging is bucking like it s fine then it sounds like it idles down - it had the ebp code and a few ohters that i posted the other day but do u guys have any thoughts or advice
thanks
thanks
Probably loose wires inside the valve cover gaskets. Very common problem with our trucks. You have to remove the valve covers to gain access and then fix it. Pay close attention to how the glow plug wires are routed, on my truck they were rubbing on the pushrods and caused a short.
Some pictures.
https://www.ford-trucks.com/forums/2...or-wiring.html
Some pictures.
i should have mentioned this - a few days ago all you had to do was take out the icp sensor and clean it with brake fluid and the truck ran great for a day or 2 then that quit working - i cant remember if it was an ipc or an icp sensor but is there a way to bypas or wire around the sensor - or should i just get a new sensor - but i will mention the wiring to him
