push rods?
Old Aug 31, 2006 | 03:14 AM
dieselburner6.0's Avatar
dieselburner6.0
push rods?
A few weeks ago i stripd a 460 down to the block, thinkin i wasnt goin to be puttin it back together i never took note of which Push Rod went with what lifter/rocker. after runnin a few numbers, i had the block bored .30 over, crank turned .10, pistons / bearings are clevite 77. the cam will be replaced with a edelbrock performer plus kit with new hyd lifters (non adj), the true roller timing set (#7830) and stock heads. with all that said, does it matter which hole i put them in when i reassemble? thanks for all or any comments.
Old Aug 31, 2006 | 03:32 AM
darrin1999's Avatar
darrin1999
id say mic them and make sure theyre all the same length and you shouldnt have a problem as long as you didnt have the block decked or heads milled and used the stock thickness head gasket... if any of these things i mentioned got screwed with get a length checking pushrod and get custom aftermarket pushrods... theyre only a hundred dollars or so and will save you massive problems in the future. also if you change your rocker ratio youd need custom pushrods
Old Aug 31, 2006 | 07:38 AM
greenhighboy's Avatar
greenhighboy
When you put the motor back together check the lifter pre-load on each lifter. Get a Crane shim kit that cost about $10 and shim each rockerarm to get the preload that the camshaft manufacturer reccomends. It takes a little time to do but makes for a better running and longer lasting motor. I did a motor a while back and had to get +.060 longer pushrods. They were about $30 from the autoparts store.
Old Aug 31, 2006 | 10:40 AM
dieselburner6.0
thanks, ill double check the lengths when i put them together.
